It is currently Fri Jul 18, 2025 5:43 pm
Post new topic Reply to topic  [ 40 posts ]  Go to page 1, 2, 3  Next
 Post subject: Gt Starlet peeps
PostPosted: Tue Jan 31, 2006 9:37 am
Peeps. Thought some may want to check this out.
http://www.austarletclub.com/forums/index.php?showtopic=3236&st=0
PostPosted: Tue Jan 31, 2006 9:49 am
look pretty cool, just need a t2 flange on it to make it worth while really.
1974 Moke - 998cc
PostPosted: Tue Jan 31, 2006 10:03 am
what does a t2 flange do?
Bling me up Scotty!
PostPosted: Tue Jan 31, 2006 10:11 am
well it lets you bolt on any garrett T2,T25,T25g,T28,GT25,Gt28 etc turbo onto the manifold. The standard ct9 turbois only good for around 135hp@wheels with front mount cooler, 2.5inch zaust and microtech ecu.
Wack on a T25 and for the same boost (10psi) you can have another 20hp@wheels with stock top mount cooler and ecu.
1974 Moke - 998cc
PostPosted: Tue Jan 31, 2006 10:18 am
ah i see...so would you still need this if you are doing a custom header then (eg. minimetoy's log header)?
Bling me up Scotty!
PostPosted: Tue Jan 31, 2006 10:19 am
Roundy guys might have problems fitting any T2 behind the grille I think.
What do you reckon Striped?
PostPosted: Tue Jan 31, 2006 10:24 am
this is what i am assuming too...hence why i am gonna put mine over the gearbox...and i am guessing minimetoy is doing his this way for the same reason :P
Bling me up Scotty!
PostPosted: Tue Jan 31, 2006 10:47 am
I rection its all about compromises. I'm a bit sick of my own clubman bashing so I won't do it but.... faced with choice I would, and am, making do with the ct9. Whilst Brad is correct in saying that factory they are limited, they can be modified. I am taking steps to get the most out of the ct9. This manifold will aid in doing so. Whilst the turbo is the heart of this motor alot can be done to open up the artilleries and veins right? God, i'm feeling awefully metaphorical today.
PostPosted: Tue Jan 31, 2006 10:48 am
Yep, but it'd be nice to have your cake & eat it too, eg, to be able to fit a larger turbo in the original position.
PostPosted: Tue Jan 31, 2006 10:56 am
Don't forget that, if your car is the model you think it is, it will be fitted with the ct9b. Which is a better turbo. There is a way to tell if it is. The housing of the turbo will just say Toyota and not Toyota Ct9 (as is the case on the eariler model).
PostPosted: Tue Jan 31, 2006 10:57 am
yeah...noticed that...just says toyota...
Bling me up Scotty!
PostPosted: Tue Jan 31, 2006 11:04 am
Score! I got dibs!
PostPosted: Tue Jan 31, 2006 11:08 am
What's different about the 9b?
PostPosted: Tue Jan 31, 2006 11:15 am
The larger turbo's just won't fit. Striped remember once you will always want more power, and the cheapest alternate is the bigger turbo.
Dan
PostPosted: Tue Jan 31, 2006 11:16 am
think i read somewhere it had a different number for blades on the front fan? an extra 3hp over earlier model or something????
1974 Moke - 998cc
