It is currently Mon Jul 28, 2025 1:45 am
 Post subject: my temperamental mini
PostPosted: Tue Jan 31, 2006 7:06 pm
Hi all!
i've had my mini for about a week now and i seem to have great difficulties starting up the car...
The first time i start it up is always fine but when i turn the car off for a short period of time eg. filling up the tank and turn it back on, it always fails.... i have to try at least 6-7 times for it to start.
btw car is a 88 rover auto.
what is wrong with it??????
thanks
pigeon
PostPosted: Tue Jan 31, 2006 7:12 pm
Start with ... Timing / air-fuel mixture.
PostPosted: Tue Jan 31, 2006 7:14 pm
Sounds like a vapour lock (?) problem possibly. Does your fuel line run close to your extractors? Or have I just confused everyone :? ?
Wish I was of more help :D
PostPosted: Tue Jan 31, 2006 7:16 pm
maybe wrong spark plugs and there getting to hot after running and failing to fire properly? i would look at the timing first though. Then see if its to lean, does it start ok if you pull the choke?
1974 Moke - 998cc
PostPosted: Tue Jan 31, 2006 7:17 pm
i just had the same issue.
All I did was change my fuel hose from the pump. It used to run right behind them (about 1" away). I put in a longer hose from the fuel pump to the carbie so it avoided any areas of high heat. It has stopped my car from running on (dieseling) when I turn it off, and has also made it idle better when started after driving in hot weather, and has also made it easier to start in hot weather.
No more Minis!......For now.
PostPosted: Wed Feb 01, 2006 12:05 pm
As in it just turns over after you've stopped it for a bit till it starts randomly?
Could be any number of things, starter motor migth be on it's way out, spark plugs faulty, points, condensor might be taking a while to hold enough charge?, same with the starter solenoid...
only way you'll find out is by troubleshooting as it's not a specific 'i'm 100% sure it's that' problem.
Shard
 Post subject: mm
PostPosted: Wed Feb 01, 2006 4:08 pm
Mine has similar trouble, but not consistently.
I thought maybe it was me flooding it :oops:
or just one of those quirky Mini characteristics.
Seems to occur more on hot days, so maybe it is a heat / evaporative issue.
BTW, is it normal for the accelerator to come on FAST (ie: not gradually)?
"Why mini? 'cause it's got the edge."
PostPosted: Wed Feb 01, 2006 4:14 pm
my vote is for fuel evapouration..
Throttle should be gradual just like any car Edge..
PostPosted: Wed Feb 01, 2006 9:46 pm
tried starting with the choke out as well.. but the same thing happened again today. Might have to just take it down to the mechanic and get them to check it out again. I've been back and forth from the garage every second day now... :( they don't seem too happy when they see me but neither do i.
where do you guys get your mini serviced in sydney? preferably eastern suburbs.
thanks for all your suggestions!
PostPosted: Wed Feb 01, 2006 9:48 pm
depending where you are, someone on here may be able to take a look at it for you..
I say before you take it anyway try using a longer fuel line thats routed away from any major heat sources. You may find that in this heat the fuel is evapourating. Will cost you $10 in fuel line, beats paying a mechanic to have a look.
 Post subject: ta
PostPosted: Wed Feb 01, 2006 11:30 pm
Cheers mad dude, I havn't driven any other minis!
I was thinkin it was characteristic - best look into it & maybe try yr suggestion. :idea:
