It is currently Tue Jul 22, 2025 1:28 am
 Post subject: Head Gasket ?
PostPosted: Wed Feb 01, 2006 8:16 pm
I was driving home last night when I lost power and started getting a knocking sound.Couldn't get above 50 and barely made it home.
Checked it out today and the knocking sound is coming from the back of the engine and if I pull the plugs on 3 and 4 it makes no difference to the way the car runs.Spark is there and no oil in the radiator water.
Possible blown head gasket ?
PostPosted: Wed Feb 01, 2006 8:35 pm
95% probability.. YES :cry:
Put your thumb over each of these 2 plug holes in turn and crank the motor over. No compression on both these cylinders, it's guaranteed 100% a head gasket.
PostPosted: Wed Feb 01, 2006 8:42 pm
could also be a stuck valve or burnt valve, easily checked with the rocker cover off to see if any of the valves are sititng lower on thsoe 2 cylinders.
but yes can be 90% head gasket i would say.
sorry doc had to allow 10% for crappy fuel and burnt seats etc.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Thu Feb 02, 2006 8:30 pm
Heads off and it is indeed a blown gasket.
http://www.users.bigpond.net.au/drekkus/gasket.html
PostPosted: Thu Feb 02, 2006 8:48 pm
atleast it you did it well :shock: it had a meal of that gasket :lol:
PostPosted: Thu Feb 02, 2006 8:52 pm
there is a lot of black around the gasket.
I would not use a copper gasket in the new one i would go for the ACL black gasket for the future after the head has been checked etc.
well done for finding it.
Users browsing this forum: Bing [Bot] and 91 guests
