It is currently Mon Jun 23, 2025 2:01 pm
PostPosted: Fri May 13, 2005 1:39 pm
Richard's beaut ute has made up my mind for me - my next mini/moke project will be electric!
Now I just have to finish this one first :roll:
Mike
 Post subject: More electric Mini Q's
PostPosted: Sun May 15, 2005 5:32 am
Hi Guys,
Ok, to answer some of your questions:
It takes about 3 to 4 hours to recharge most of the energy
( the last bit has to be trickled in slowly, but you can stuff the first
90% in as fast as your outlet can handle )
That's with a 13 amp 240 volt household socket. Total cost?
I'd guess somewhere under 50p. Not bad for 25 miles...
But, the real cost is the batteries - they don't last forever.
Discharging them until they're flat ( or almost flat ) is very hard
on them, even ones built to take this kind of use ( Optimas ).
If you treat a pack well, you might expect 500 cycles with sealed batteries
like mine, maybe 800 if they're flooded batteries. Then they will be
old, and have such a low capacity that the vehicle won't do your
journey anymore, so you have to replace them.
Total cost would work out the same as driving a petrol car, but that's
not the point.
The point is, the electric version is 3 times as efficient - petrol engines
throw away enourmous amounts of energy as heat ( that's why they have
water cooling and radiators ) , and you've paid for that energy!
Anyway, it's also fun to do, 'cos it's weird and different!
As for weight, yes I'm right at the limit of what I'd want to put into
a Mini, even one with stengthened suspension. You can feel that weight
on board, even with vented discs & 4 pot calipers on the front brakes.
I have thought about sinking sheetmetal boxes down into the load area
( inside the rear subframe and in the hidden area behind the seats ) to
move the batteries lower down, but am reluctant to cut BIG holes into
a genuine Mini pickup, even if it is a rough one like mine!
Fuel cells? Give me a million dollars, and maybe, but where the heck is
the hydrogen gonna come from? I'll tell you where - from oil. So you
still end up having to go to a filling station, only now you have a high
pressure bomb (10,000 PSI hydrogen tank) built into your car.
No thanks!
The photo with the tree was a stoke of good fortune - I'm lucky to
live on a nice tree-lined street, and last autumn's weather just happened
to be calm, with no windy storms to blow the leaves off the trees.
I saw that colour and thought:
" I've just GOT to take a photo of the pickup with that colour on the trees"
It really worked out well, glad you liked it too.
Whilst I'm here, does anyone know whether the Aussie-spec
doors with wind-up windows will fit into a UK-spec Mini pickup?
I hate the sliding windows - they leak all the time!
Regards
Richard Bebbington
electric Mini pickup
PostPosted: Sun May 15, 2005 6:53 am
Richard,
Early Oz Mini Deluxe or Cooper S doors should bolt straight into the UK pickups, which use MK1 style doors. The later ones (Oz Clubbie type) with lift up latches will not- the B pillar is different. :wink:
Both these doors have the same quarter vents & wind ups.
PostPosted: Wed Feb 01, 2006 12:10 pm
if you are going to stay with a conventional lead acid battery, why not invest in these reconditioning franchises. i hear it costs about $1.00 AUS to recondition back to about 95%. would make it better...
http://www.minisport.com.au
the guys there are dead set champions
PostPosted: Wed Feb 01, 2006 4:12 pm
I'd love to have the time and the gear to try something like that. A most excellent project!
...'though it needs recorded A-series engine noises so you don't (sneak up on and)scare the horses! :lol:
1958 Morris Minor 1000 - "Nigel"
PostPosted: Thu Feb 02, 2006 3:27 pm
it really doesn't seem that hard ( :wink: remember the last time you said that?) the things that are really worth looking into are batteries, chargers (on the fly and standstill)
i won't look at tackling it until i can guarantee 200 km range from it. the avaerage these days is about 150. maybe look at the prius. i was told that they have some sort of charging system off of there brakes...
PostPosted: Thu Feb 02, 2006 5:06 pm
Not many do-it-yourself electric car conversions have regenerative braking.
It's not that hard to do (there is that phrase again) but the controllers to do it have only been on the market a couple of years.
It adds more than 50% to your city driving range :)
PostPosted: Thu Feb 02, 2006 5:07 pm
PostPosted: Thu Feb 02, 2006 8:56 pm
cush wrote:
and it would make it more mini like....you know... not being able to drive in the rain :)
:lol: :lol: :lol: :lol:
PostPosted: Fri Feb 03, 2006 8:58 am
wow, i had the chice of 2 to choose from there... :wink: wouldn't mind a bit of info on the braking system, or some links to info...
PostPosted: Fri Feb 03, 2006 9:55 am
Here are a couple of interesting EV links:
http://www.metricmind.com
http://www.acpropulsion.com
http://www.metricmind.com/ac_honda/main2.htm
I love the AC Propulsion controller/charger as fitted to the Tzero 8)
but at over $20k only in my dreams :(
PostPosted: Fri Feb 03, 2006 10:15 am
my uncle works/worked on a system like that..
PostPosted: Fri Feb 03, 2006 1:19 pm
do tell.......
PostPosted: Fri Feb 03, 2006 1:55 pm
i just did... :)
http://www.permodrive.com/
oh... it was for trucks... :)
but not electric ones.. :(
PostPosted: Sat Feb 04, 2006 3:42 pm
interesting..... would be great in a rear wheel situation..... mmmmm
