It is currently Wed Jun 25, 2025 2:36 pm
 Post subject: Subframe Help..
PostPosted: Fri Feb 03, 2006 6:53 pm
I'm planning on changing my subframes over from Wet to Dry, I've been reading a few posts regarding dry subframes and there has been mention of spacers that go between the tower and the body. I don't have any, and was wondering if they could be made? What are they made from? and does anyone have a picture of what they look like? size and dimensions if possible. or even better, know of somewhere in Melb that I could get some from..
Mat
PostPosted: Fri Feb 03, 2006 7:06 pm
Any place that sells s/h Mini parts (eg Northern Mini Parts) would have them. they are oval shaped with 3 holes in. Only were used on dry subframes. Why? No idea... :lol:
PostPosted: Fri Feb 03, 2006 7:14 pm
Thanks again doc, as it happens I need to head there tomorrow anyway, will ask and see what turns up.
Mat
PostPosted: Fri Feb 03, 2006 8:26 pm
Are they needed then? What exactly do they do?
PostPosted: Fri Feb 03, 2006 9:30 pm
the spacers are needed - the dry subframe has a lip on the bolt hole and the big hole that would crush up into the crossmember if the spacer wasn't there - the subframe tower is physically shorter
no-one ever believes me, but it's dead simple to use rubber cones in hydro subframes, I did that with my blue S...
PostPosted: Fri Feb 03, 2006 9:43 pm
Well I believe you as I've got a pair of wet frames that I've trial fitted dry cones to, all seems well.
PostPosted: Fri Feb 03, 2006 9:56 pm
The Beauty is that if you use the Hydro top arms, you actually get a HIGHER spring rate than with Dry arms !
dont forget to drill the top arm to take a larger bolt needed for the Shock-absorber though....
Mine has COnes in a Hydro subframe with Hydro top arms..... those that have driven it say it rides a LOT firmer than most dry cars....
A combination of worn-out Clubman cones, Hydro top arms, Gabriel Gas shocks, and Hi-Los ....
J
