It is currently Fri Jul 18, 2025 10:37 am
 Post subject: Noise ?
PostPosted: Sat Feb 04, 2006 11:06 pm
When driving along the car makes a sort of grating noise when the throttle is down , when I lift off it goes away, its not the throttle itself maybe drive shaft im not sure anyone had this ? :?
1977 Clubman
PostPosted: Sat Feb 04, 2006 11:30 pm
I think we will need a bit of a better desciption..
Does the noise increase/match with engine revs? or is it a constant sound maintaining pitch and volume?
PostPosted: Sat Feb 04, 2006 11:36 pm
erm yeh increases but only when the car is moving, so I suppose as it goes faster not the actual revs sorry. i can rev it stationary and no sound ?i dont think its a wheel bearing as it sound mor central to the car - sort of under your feet area
1977 Clubman
PostPosted: Sun Feb 05, 2006 8:37 am
Does the steering start to get jerky and the steering wheel move on its own once you get past 30mph?
PostPosted: Sun Feb 05, 2006 11:02 am
No
1977 Clubman
PostPosted: Sun Feb 05, 2006 1:55 pm
If it's got rubber uni's check those for movement. Mine were so worn when I got the car, they were hitting the back of the gearbox! Thats my limited experience 2 cents worth. :D
PostPosted: Sun Feb 05, 2006 8:44 pm
maybe check around your drive shaft I had a peice of the radiator shroud fall of and onto the drive shaft Causing a Scarey rattle and grind at speed. check every where and anywhere that has anything to do with the drive shaft Or moving wheel Parts.
