It is currently Sat Jul 19, 2025 10:44 am
PostPosted: Mon Feb 06, 2006 9:08 am
So is this a legitamet (sp) was to lower a dry mini? I would like to do this
on my 74 Clubby (obviously dry). I have heared that it is not good to do this,
but if using the correct measurements from Vizard, is there anything wrong
with doing this?
I would fit Hi-Lo's but i dont have the money,,, and this car has got to drop some :wink:
PostPosted: Mon Feb 06, 2006 9:14 am
Have you got a lathe?
You'd only be removing about 5mm tops I'd imagine.
Much more and you'll need spacers again.
PostPosted: Mon Feb 06, 2006 9:37 am
I've found it to be safe , just make sure you double check the measurments and ratio's as they are different for the front and rear , just can't remember off hand . One was 1:5 (front?) I think and the other 1:3 ? In other words for evey inch you cut off that's how far the suspension will drop , a little cut will make a big difference to height so make sure you get the measurments formo a reputable source , if you're using Vizards info then you should be right .
PostPosted: Mon Feb 06, 2006 9:49 am
thanks mate!
Its just once i was contemplating doing this and someone said that
it is not a good way as it stuffs up the suspension and that Hi Los were
much better,
But the way i see it. it is basiucally the same principal. you either have a short metal
bar (hi lo) or a short trumpet.. no real difference?
PostPosted: Mon Feb 06, 2006 9:59 am
And remember , you'r only cutting 1/4" or so off anyway , not actually weakening it . All I'd suggest is to choose a cooler method of cutting it off , with a hacksaw or on a lathe as opposed to a grinder with a cutoff wheel .
PostPosted: Mon Feb 06, 2006 10:03 am
excellent thanks mate. will take them down to the local machine shop and
get them to stick it on a lathe!
PostPosted: Mon Feb 06, 2006 10:09 am
It's the other way around- fronts are 1:3 and rears 1:5. :wink:
PostPosted: Mon Feb 06, 2006 10:12 am
thanks.
So is it worth cutting the front also? im not replacing the cones. so they may be
flat from the engine. how much does it lower the car. I dont want it to be riding on its
bump stops
PostPosted: Mon Feb 06, 2006 10:14 am
czerial wrote:
thanks.
bump stops
1/4" off fronts will lower 3/4" approx.
cut them straight...
PostPosted: Mon Feb 06, 2006 10:15 am
Thank's Kev , couldn't remember off hand and couldn't be bothered searching since czerial mentioned having the books . I've seen what happens when somebody decided to lower a mini all round by two inches , removed all 4 trumpets while the car was on stands and cut two inches of each trumpet before refitting them all .... :lol: Bump stops all the way around :o ...
PostPosted: Mon Feb 06, 2006 10:19 am
thanks guys :wink:
PostPosted: Mon Feb 06, 2006 10:28 am
Just check that there isn't some spacer washers on your knuckle joints already you might not have to cut anything off :wink:
There was also a bit about lowering minis by cutting the trumpets on minimania's website here we go this looks like it:
http://www.minimania.com/web/SCatagory/SUSPENSION/DisplayType/Calver%27s%20Corner/DisplayID/1231/ArticleV.cfm
Roads need more corners
PostPosted: Mon Feb 06, 2006 10:33 am
thanks mate :wink:
Users browsing this forum: Bing [Bot] and 96 guests
