It is currently Sat Aug 02, 2025 10:00 pm
Post new topic Reply to topic  [ 55 posts ]  Go to page Previous  1, 2, 3, 4  Next
PostPosted: Mon Feb 06, 2006 2:22 pm
*cough* handbrake *cough*
PostPosted: Mon Feb 06, 2006 2:23 pm
i dunno, just goin off what Cush said. :lol:
PostPosted: Mon Feb 06, 2006 2:28 pm
Yeah i must get around to oiling the pivot part up... that squeak when the handbrake is pulled up is driving me insane.
PostPosted: Mon Feb 06, 2006 2:32 pm
:roll:
i'm not talking about the operation of the said handbrake...
more when it is used....
PostPosted: Mon Feb 06, 2006 2:33 pm
are 1300's as much fun to do that in as minis?
PostPosted: Mon Feb 06, 2006 3:47 pm
Better :oops:
The ass swings around way nicer and is (i feel - maybe its just cos its auto) a lot easier to slide through a corner with the power down.
PostPosted: Mon Feb 06, 2006 4:03 pm
:roll:
PostPosted: Mon Feb 06, 2006 4:29 pm
willy wrote:
Yeah there will be strictly NO abusing the mighty 1300.
Just cruising... :)
:roll: :roll: :roll: shakes head sadly
Roads need more corners
PostPosted: Mon Feb 06, 2006 4:38 pm
:lol: Don't mock it till you try it.
The car wasn't built for abuse, but i'll train it to take it.
Nope... no thrashing just a bit of fun with the old (and hard) tires.
PostPosted: Mon Feb 06, 2006 7:40 pm
i see the engine mounts and exhaust need to be "re-educated"
:roll:
PostPosted: Mon Feb 06, 2006 7:42 pm
:roll:
Steve did the engine mounts and the exhaust while the previous owner owned it.
The exhaust was patched when the previous owner still owned it, so you can't expect much from that.
PostPosted: Mon Feb 06, 2006 7:54 pm
Will has the floats on fluid sticker rocked up yet?
PostPosted: Mon Feb 06, 2006 8:03 pm
I don't think the 1300 had them.
But I wouldn't mind one! :wink:
PostPosted: Mon Feb 06, 2006 8:34 pm
Not sure at all as i haven't been to Brickworx for a couple of days (getting withdrawl symptoms)
I will let u know as soon as i find out.
edit: Steve informs me that they have arrived (have been there for a few days)...
PostPosted: Tue Feb 07, 2006 10:33 pm
1300..?!
Landcrab..?!
Err, guys, the pics are of a Morris 1500.
They are nice pics too, but I should point out that the 1300 uses the 1275 (1100S motor in Australia) A Series engine, whereas the 1500 has a 1500cc overhead cam engine (I don't know the series type.) and five-speed gearbox with cable operated gear-change.
The Land Crab, as it is affectionately known, is the Austin 1800, which uses a B Series engine - like the MGB (for the Mk2 anyway).
The front grille is quite different on the 1500, whereas the 1300 and 1100 are very similar - and IMHO much better looking. Easiest way to tell the 1100 and 1300 apart is the taillights - 1300s are flat. Also, as stated, in Australia it would be an 1100 S, not a 1300.
So, the 1100 and 1100 S are both closely related to the Mini, kind of a big Mini with 4 doors (a Biggi perhaps?), whereas the 1500 and 1800 are quite far removed from the Mini/1100 concept, despite the initial similarity in appearances.
Here endeth the lesson.
Cheers, Watto.
:shock:
