If it's a Mini Deluxe with remote, it's possibly the old Deluxe gearbox still (no synchro on 1st) or maybe it's been replaced with a Mini- K `4 synchro' box. They look pretty much the same from outside..
Check the number
cast on the front of the box, behind the oil filter.
If 22G1128, it's a Mini- K or Clubbie remote box. Stronger than the early 3 synchro ones, they have the same gearset as the `A' series rodchange boxes.
Remote boxes are better located than rod change.... They don't climb around in the car when you change gear..
<edit> Oh yeah, the floor...
I did the 2 front pans on my 850 and it went pretty well with MIG-
Make sure car is level when you start- don't do it hanging on a Mini sidejack..
Do 1 side at a time
Make sure the doors still fit properly as you go
Don't cut thru the battery cable, or fuel, hydro, brake lines...!
Note-
Karcraft's panels are UK made- won't fit an Oz hydro floor too well, unless it's a real early Deluxe (without the tray pressings underneath).
DrMini- 1970 wasaMatic 1360, Mk1S crank, 86.6HP (ATW) =~125 @ crank, 45 Dellorto (38 chokes), RE282 sprint cam, 1.5 rockers, 11.0:1 C/R.
