It is currently Sun Jul 27, 2025 2:56 pm
PostPosted: Tue Feb 07, 2006 8:52 am
Klubman wrote:
Doc, am I dreaming or have I seen somewhere that you have done a wet top dry conversion without changing the subframes?
Yes you can do a wet to dry conversion using the wet subframes I haven't done it but I am told it's possible 8)
Roads need more corners
PostPosted: Tue Feb 07, 2006 8:54 pm
Yes our Barney has a wet front subframe with rubber cones and Konis, with Hi-Los.
Rear is a Clubby dry, I think. But yes you can put rubber cones in wet rears too.
PostPosted: Tue Feb 07, 2006 9:03 pm
if hydro is so bad, then how come all the cooper s's had it, and used it in rallies and races most of the time??? it cant be that bad really, i wouldnt bother changing it, as was sed, just out some shocks on the front.
Potato
PostPosted: Tue Feb 07, 2006 9:53 pm
Meeni, there's a wicked conspiracy afoot to get rid of all hydro suspensions because they handle and ride better than dried out rubber cones do... :wink: 8) :lol:
Must be bad, lol- they used a derivative (Hydragas) on the MGF too.
will now remove tongue from cheek... :P
PostPosted: Wed Feb 08, 2006 6:51 am
im in the process of changing a car from hydro to dry right now cos the guy wants it done.
I know my mate rolled his ini on hydro set up and refuses to rally it now.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Wed Feb 08, 2006 1:33 pm
for me its not a handling thing its a lack of parts being available off the shelf thing
