It is currently Sat Jul 19, 2025 11:32 am
 Post subject: Bumpy ride?
PostPosted: Wed Feb 08, 2006 6:56 pm
I have a dry suspension and is very bumpy.
How can I get a smoother ride?
Lucy - 64 cooper s replica
Lulu - 66 deluxe
PostPosted: Wed Feb 08, 2006 8:22 pm
New Shocks + Cones + 10" Wheels with soft rubber ie. A008's.. is about the best you are going to get without going hydro..
PostPosted: Wed Feb 08, 2006 8:26 pm
convert to hydro or buy a Nissan Pulsar :lol:
Mini's....worse than drugs, but a much better FIX ;-)
PostPosted: Wed Feb 08, 2006 8:29 pm
Haha..move somewhere with smoother roads..that wouldn't be anywhere here..:lol:
Seriously though, it is a mini..i wouldn't expect too much, though mine is pretty good after i replaced the cones. Doesn't 'jolt' you anymore on a big bump, you notice them still, but it doesn't 'hurt'...i suppose at almost twice the thickness and soft rubber it's gotta make a difference.
PostPosted: Wed Feb 08, 2006 8:45 pm
Gotta love HydroSpastic, nah its a good ride on hyrdo
Jet Red Mini K
PostPosted: Wed Feb 08, 2006 8:53 pm
I find my hydro to be a little bumpy, but if I drive fast enough I dont notice after a while :P
1978 Leyland Mini 998LS All Original *Sally*
2002 Mini Cooper *Coopa*
PostPosted: Wed Feb 08, 2006 9:40 pm
Maybe some nice new rubber cones then?
Where is the cheapest to buy?
Lulu - 66 deluxe
PostPosted: Wed Feb 08, 2006 9:46 pm
As you are driving in Tassy..I'd say the cones have saged so they need replacing..
Beffa I'd say your riding on the bumpers stops and the Hydro system is low..I think I worded that nicely ..it almost came out the wrong way
PostPosted: Wed Feb 08, 2006 11:40 pm
ah....welll,,,,another candidate for my "soft Hi-los"
I make a set of small foot hi-los that make your dry suspended mini feel like a hydro
they are beautiful
Billett machine grade alloy & only $160 per set of 4
you`ll need 2 x hydro rear suspension rods to fit the 2 rear ones & i`d also fit a new set of Nylon cups & call kits while you`re there
easy-peasy & soft as :-)
BEAUTIFULL aren`t they??????????????? :-)
PostPosted: Thu Feb 09, 2006 10:51 pm
hey
does the size of the hilo really make a difference in how it performs??
i have some "heavy duty" ones that have been galvanised. they fit nicely..i feel a slight difference in the back. (not done the front yet)
One problem i have with them is that the bolt doesnt screw all the way in. It needs to have thread all the way to the head of the bolt..slightly dissapointing considering i payed 50 dollars for each of them.
1978 Leyland clubman S.
PostPosted: Thu Feb 09, 2006 11:16 pm
these are My hi los
anyone else got these?
PostPosted: Fri Feb 10, 2006 11:25 am
It is the contact surface of the hi-lo onto the rubber. A big surface, especially one that is shaped towards the cone, will give a stiffer spring rate. Small contact surface and/or curved away from the cone = softer.
