It is currently Thu Jul 24, 2025 11:06 am
 Post subject: Ramps..
PostPosted: Thu Feb 09, 2006 5:34 pm
Got tired of walking on my knees when working on the LS or Moke, so I built these...
PostPosted: Thu Feb 09, 2006 5:42 pm
you must be quite short.... ;)
a good idea tho.... beats digging a pit :)
PostPosted: Thu Feb 09, 2006 5:44 pm
I still bump my head on the exhaust tho cush... :?
PostPosted: Thu Feb 09, 2006 6:15 pm
More chance of dropping a spanner on your head now also.. :wink:
Nice job 8)
PostPosted: Thu Feb 09, 2006 8:32 pm
nice... :)
why not make it so the middle section between the wheels can be removed so you can work under it without them in the way if it's up there for a while?
PostPosted: Thu Feb 09, 2006 8:47 pm
Cause that would need more bracing. :D
PostPosted: Thu Feb 09, 2006 9:03 pm
whinger
PostPosted: Thu Feb 09, 2006 9:49 pm
Lateral ? thinking - I like it :idea:
Just have to remember not to park the wife's van on it
 Post subject: ramps
PostPosted: Thu Feb 09, 2006 10:32 pm
I'd hate to see my missus try and drive anything up those :P ..........
I wouldnt have thought timber would be able to handle the load of a mini or moke, proves that wrong hey....
PostPosted: Thu Feb 09, 2006 10:37 pm
Its pretty meaty timber!
I can't see it breaking any time soon.
Out of interest, are they roofing beams?
Be careful using that now, won't you...
PostPosted: Fri Feb 10, 2006 7:59 am
listen to you.... :roll:
PostPosted: Fri Feb 10, 2006 8:05 am
skssgn, the middle support legs are floaters so they can be removed if need be...
850pete & willy, the timber is 300x45 treated pine and with the middle support in place when driving on, there is no problems at all..
I am going to put some timber along the inside edges to stop the chance of driving off the sides...
PostPosted: Fri Feb 10, 2006 8:50 am
hahaha willy and his mum!!
they look pretty good, i would still like a pit, untill it rained!
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Fri Feb 10, 2006 9:16 am
Smokie, that is friggin AWESOME!! Well done mate. Once I extend the garage I'm doing that for sure.
Any chance of providing all the measurements/specs for it? Maybe even pop something in the How to?
Brilliant work mate.
BC.
PostPosted: Fri Feb 10, 2006 11:53 am
I have seen the same thing in a garage, but it all folded down towards the ground when not in use... kinda pull it towards the ramps and it folds down to the floor.... using pin hinges. you don't need to find another storage area for the ramps and can still use your garage.
I have eyed off some steel at work which is quite suitable for the job too!!
but that looks really good and works well congrats!!
