It is currently Sun Jul 27, 2025 8:37 pm
 Post subject: Wheel Bearings
PostPosted: Fri Feb 10, 2006 10:17 pm
Does anyone know what the part numbers are for the wheel bearings on a 74 clubby? Also are they Tapered or roller? hmm just thought I would replace them. Any help would be appreciated.
PostPosted: Sat Feb 11, 2006 5:40 am
Standard front wheel bearings are now GHK1018 $53.01/pr includingseals.
These are angular contact ball type.
I think old part no was 16LJT 1-1/4 then 16LJT 31.75
The Cooper S tapered roller kit will fit too, latest p/no is GHK 1140 $60.42/pr including seals.
These prices are for 1 side only, you need 2 kits.
I only use the taperred roller kits now, they last far longer and have about 2x the load capacity.:wink:
PostPosted: Sat Feb 11, 2006 7:06 am
Thanks Dr Mini :D
PostPosted: Sat Feb 11, 2006 7:09 am
Where is the best place to buy them from?
PostPosted: Sat Feb 11, 2006 7:41 am
These prices were from my Karcraft catalog.
www.karcraft.com.au
email [email protected]
:wink:
PostPosted: Sat Feb 11, 2006 10:20 am
try a general bearing place like SKF if you have one nearby - they tend to be cheaper, and they list the same kits
PostPosted: Sat Feb 11, 2006 11:22 am
If you pick them up from UK Minispares as "Classic Wheel Bearing Kits" they are Timken taper roller bearings by default. I paid 25 dollars a side a couple of years back, but that was then.
Mick
Users browsing this forum: fuzzy-hair-man, Goldbrocade_62 and 95 guests
