It is currently Fri Jul 18, 2025 1:51 pm
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6  Next
PostPosted: Sun Jan 22, 2006 7:06 pm
And the hammer together ones are bloody sharp, i have the scars to prove it... :cry:
yeah they were a bit edgy...i have learned the hard way to wear gloves in the garage whenever doing this kinda stuff though...as you say: i have the scars to prove it :P
they were actually easier to put together than the crane...atleast the instructions were pretty easy to follow with the shelving :P
Bling me up Scotty!
PostPosted: Wed Jan 25, 2006 11:24 am
'Zuma, if that garage has a concrete ceiling you should be able to drill into that pretty easy. I did that at a rental place I was staying at and they had no problems, I just left the hooks in there. I just used wall plugs (the plastic ones) and they worked fine.
I got some 2ft flouro lights out of the trading post for $10 each, $2 powerboard and $2 extension lead and it gave plenty of light. I just used cup hooks screwed into the ceiling and builders string to hang them.
I also use the hammerlock shelving. It's handy for the price, just don't get the tops wet and watch those corners! I also had a 4ft twin over the workbench (that I made out of a couple of half height hammerlock shelves).
PostPosted: Wed Jan 25, 2006 11:40 am
nice! the light idea is good...i'll ring the realestate agent and see if they'll let it fly...
Bling me up Scotty!
PostPosted: Fri Jan 27, 2006 3:23 pm
ok...the time has come to purchase a proper workbench...i know the shelving i bought can be used as a workbench...but i am not too keen on that idea...any suggestions as to what would be the best thing for a workbench?
Bling me up Scotty!
PostPosted: Fri Jan 27, 2006 4:47 pm
Location: thornleigh sydney...round crnr from suzitech!!!!
an old clubby bonnet...LOL
hehehe...its lookinh good mate,
blake :wink:
ausmini member 195
71K 'Kaye', KAZZ69's work in progress
66 panelvan, going no where fast...
71 MS75 toyota crown COUPE :) yes A COUPE!
76 ra23 celica wid 1ggte, GT3071r, 13.5@106mph with alot of spinin....
wheels keep on turnin!
PostPosted: Fri Jan 27, 2006 8:44 pm
Andrew,
I would buy some 2nd's steel from the scrap metal merchant and weld your own up.
This would give you three things: a strong workbench, a cheap workbensh, practice in welding steel.
Then just ocver it with some 20-25mm ply (preferably form ply or some other HD).
My two cents. :wink:
Andrew
PostPosted: Fri Jan 27, 2006 9:28 pm
not a bad idea andrew...also means i can make it to my own size requirements...as you know space is at a premium in my garage :P
btw...what sticks did you use to weld up your jig? or did you mig it?
Bling me up Scotty!
PostPosted: Sun Jan 29, 2006 11:49 am
yummy..
Bling me up Scotty!
PostPosted: Sun Jan 29, 2006 11:54 am
Don't look now but I think someone put chocolate mousse in your CVs :lol:
PostPosted: Sun Jan 29, 2006 12:03 pm
2 flavors too :P the driver's side one is definitely milk chocolate...the passenger's side one is a little more blue berry based i think...only one way to find out :P heh
Bling me up Scotty!
PostPosted: Sun Jan 29, 2006 12:18 pm
Is that your new workbench in the back ground, just screw off a bit of ply to the top of the shopping trolley and you have a portable bench.
Dan
PostPosted: Sun Jan 29, 2006 12:28 pm
Dan
that shopping trolley is in a few too many pieces to worry about putting it back together :P
Bling me up Scotty!
PostPosted: Thu Feb 09, 2006 10:09 am
finally found a decent workbench...tradingpost spesh...arriving friday...will post pics when its here :)
Bling me up Scotty!
PostPosted: Sat Feb 11, 2006 10:50 am
finally got my new steel workbench in my garage:
with my sexy big vice (came with the bench):
and a nice big bench grinder:
all for the low low price of $320 including delivery from redcliffe! BARGAIN!
only need 4 more things till i can start my subframe construction:
-steel cutting mitre saw
-tecmen welding mask
-dry front subframe
-LOTS of RHS
Bling me up Scotty!
PostPosted: Sat Feb 11, 2006 11:22 am
What will you use this for? Cutting the RHS?
