It is currently Thu Jun 26, 2025 11:18 pm
 Post subject: Crosspin diff info
PostPosted: Sat Feb 11, 2006 9:04 pm
I'm about to bung Cody's nice shiny new MiniSpares Bling crosspin diff into his S box.:)
Anybody know WHY the diff pins are not at 90* to each other? Looks strange- they intersect at 80* or so.... :?
PostPosted: Sun Feb 12, 2006 9:00 am
hmm thats odd :? spoze if the teeth mesh properly it doesnt reall matter, looks as if the other holes are in the way to make it 90deg
PostPosted: Sun Feb 12, 2006 9:02 am
This one looks different from the one Cody/Kev has. The centre bit is more of a rectangle than a square. It definately looks odd as it's definately 10-15 degrees off square :shock:
PostPosted: Sun Feb 12, 2006 11:48 am
Used to be called the 'MiniTorque Diff' before Minisport bought it. I had one of these when they first came out, lasted about 3 Months when I finally got round to fitting it. Went the same way as my standard diff had ! One of the pins came out, wiping out my Mk3 S/1275GT box. I had got it from Mini-it's and they where fantastic about it, got the manufacturers to replace it even though I had had it about a little over a year old. The Mk2 version which is the one Minisport sell now has a cap headed bolt to stop the pins coming out. But I decided after looking at the Minispares diff to use theres instead. Much better design in my opinion, probably because it was designed by 'Neil Booth a gearbox specialist' and also proprietor of Minispares North in the UK.
PostPosted: Sun Feb 12, 2006 3:58 pm
Thanx for that, I've also heard that the MiniSport UK one is a POS :cry: and the MiniSpares is the one to get. :)
PostPosted: Mon Feb 20, 2006 6:42 am
Having now fitted it all up, I'm impressed with the workmanship in this Mini Spares one. Very nicely made, worth it I reckon if you need one for a Hi-Po motor, turbo etc. 8)
Note those thrust washers they show should have been staked into the slots provided.. :lol:
