It is currently Sat Jul 26, 2025 11:42 am
PostPosted: Sun Feb 12, 2006 4:18 pm
I've just fitted a new roof lining to my mini, and now I need to cover those bits that cover the pillars between the side and rear windows, the old one's are rooted.. Has anyone made their own? If so what did you use for the backing, to get the curve in them, the old ones look like they are made of cardboard..
Mat
PostPosted: Sun Feb 12, 2006 7:47 pm
i used the front cover of my art book, its 1.5mm thick plastic/perspexy kind of stuff... works a treat :)
PostPosted: Sun Feb 12, 2006 8:00 pm
To get the curve, dampen the card and lay it on something that has a similar curve, like a petrol can for example.
Lay a towell over it, to hold it to the can, and leave it for a week (preferably in the heat).
It will dry to the correct curve and stay that way
:mrgreen:
Website: www.justanothermini.com
PostPosted: Sun Feb 12, 2006 8:09 pm
Has anyone tried using 3mm MDF to make curved panels in the same way?
Would it work?
1958 Morris Minor 1000 - "Nigel"
PostPosted: Sun Feb 12, 2006 8:14 pm
Would it work?
anyone feel free to correct me, but surely 3mm wouldnt be that easy to shape? and it would want to pop out all the time... unless maybe you soaked it in boiling water, pressed it to shape then allowed it to dry...
but i think it would be too difficult/thick... :?
PostPosted: Sun Feb 12, 2006 8:16 pm
Thanks for the reply guys.. I'll see what I can find and give both a go.
PostPosted: Sun Feb 12, 2006 9:06 pm
3mm mdf would be too thick i think :?
i would just find some old ones, or just use cardboard, thats all mine are
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Feb 13, 2006 10:37 pm
Using siclad_5's idea, I went to officeworks today and got an A3 display book with black plastic covers, big enough to make 2 of them thingamies out of, I haven't got around to doing a trial fitting yet, coz I got called in unexpectedly to work.. How rude... will let you know if it works out.. :D
Users browsing this forum: Bing [Bot] and 85 guests
