It is currently Thu Jul 24, 2025 6:23 am
 Post subject: Wheel big issues
PostPosted: Mon Feb 13, 2006 1:27 pm
Ok the engineer wont pass 13" by 7" wheels on my van because they are more than an inch wider than standard :evil: , has anyone else got them passed legally or can i just put them on after? Now im in a *%$# mood. :x
PostPosted: Mon Feb 13, 2006 1:59 pm
Maybe you could point out that later model Minis with the same (or very similar) suspension components came factoy fitted with 13X 6 wheels...
Cheers, Ian
PostPosted: Mon Feb 13, 2006 2:23 pm
chuck on some old stockie wheels that fit well inside the flares. onced past and rego'd pull em off and put ur other 13s back on. They can defect you even if the side wall of the tyre is outside the flare, in which i believe is wrong because the side wall doesnt flick stones up because there is no tread, but thats how they do it.
Image Image
PostPosted: Mon Feb 13, 2006 2:46 pm
maby try 13*6s with spacer drunms???
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Feb 13, 2006 6:31 pm
i've gotta have at least 12's to fit over the discs cause its 1360, and the 13's do fit under the flares so maybe i'll change them after rego?
PostPosted: Mon Feb 13, 2006 8:57 pm
Dean (Baracade) has his 13x7's engineered here..
Users browsing this forum: Bing [Bot] and 91 guests
