It is currently Wed Jul 23, 2025 9:26 am
 Post subject: Engine Numbers
PostPosted: Mon Feb 13, 2006 3:18 pm
hey
Being relatively new to mini's and not yhet owning one im unsure about acouple pf points, yet im looking at one on wednesday night and it is supposedly a clubman with a 1275 engine, and i know that you can tell the engine size off the engine number, but i was just wondering where on a mini's engine is that located and wat prefix's would i be looking for???
Thanks
Hi-Ho Silver LS1275
PostPosted: Mon Feb 13, 2006 3:32 pm
Engine number is stamped on top of cylinder block, below #1 spark plug.
All 1275s- the engine number starts with 12, except Cooper S.
PostPosted: Mon Feb 13, 2006 3:39 pm
except Cooper S.
... which start with 99h....
:roll:
PostPosted: Mon Feb 13, 2006 3:41 pm
cush wrote:
except Cooper S.
:roll:
WRONG...
Go stand in corner...NOW! :lol:
Mk1 S motor was 9F/Sa/H
Mk2 S motor was 9F/XE/Y...
PostPosted: Mon Feb 13, 2006 3:51 pm
Ii'm afraid you're gravely mistaken, kev...
99h791 is defninatley a cooper s number....
:roll:
edit
actually 9F/Sa/L is the cooper (low comp) engine number? if i remember correctly
PostPosted: Mon Feb 13, 2006 3:53 pm
Thanks fellow's
So which is it 9 or 99?????
Hi-Ho Silver LS1275
PostPosted: Mon Feb 13, 2006 4:01 pm
9 :wink:
PostPosted: Mon Feb 13, 2006 4:04 pm
99H/whatever is a common UK built 998 motor, Cush. NEVER a 1275.
first use of 99H here was on MiniMatic, it was 99H/119/H.
PostPosted: Mon Feb 13, 2006 5:22 pm
MiniMe87,
Just post the first half of the engine number and we will tell you what it is.
The same with the VIN or chassis number.
PostPosted: Mon Feb 13, 2006 5:31 pm
i will, but i wont no it till wednesday which is when im looking at the car, thanks for all the help!!!
Hi-Ho Silver LS1275
PostPosted: Mon Feb 13, 2006 6:11 pm
Also have a look under the carby/exhaust manifold , if there are no bolt on plates under there then it is an 1100S motor which is actually a 1275 (most common one in vehicles here now) , also a Cooper S motor (but not an 1100S motor) should have 2 extra head studs , 1 on either side of the rocker cover , 1 near the heater tap/outlet and the other sort of near the thermostat housing . Of course if it hasn't got a cooper S head they probably won't be there either . As morris1100 said though , get the engine number prefix and post it here and we'll tell you what it is . If it starts with a 12 it should be an 1100S , if it starts with a 9 it couls be a cooperS or a 998 cc motor , post everything before the numbers at the end and we'll sort it out .
PostPosted: Mon Feb 13, 2006 6:33 pm
" if there are no bolt on plates under there then it is an 1100S motor "
Hmmm, I've had 2 1100S engines now WITH the plates.....
Dont trust anything from Australian BMC or Leyland.. .there was no real quality control and almost ANYTHING came out of the factory.....
:roll: No hard and fast rules I think...
J
PostPosted: Mon Feb 13, 2006 6:34 pm
Cush is questioning the Master??? :shock:
In this case the doc is right (like der)
PostPosted: Tue Feb 14, 2006 7:52 am
nah.. the doc is just wrong... 99h791 is the only cooper S engine number.... ergo... it's the best engine to have...
:oops:
PostPosted: Tue Feb 14, 2006 8:44 am
cush wrote:
except Cooper S.
:roll:
WRONG...
ummmm I believe the Mk1 S motor is 9F/Sa/Y as on my engine and everywhere I've read.
2002 FORD FALCON AUIII XR6 VCT- 3984cc
Previously owned :-
1968 Morris Cooper S
1967 Morris Mini Van
1978 Leyland Minni Clubman
