It is currently Tue Aug 19, 2025 6:20 am
Post new topic Reply to topic  [ 37 posts ]  Go to page 1, 2, 3  Next
 Post subject: mk1, mk2, mk3...
PostPosted: Wed Feb 15, 2006 2:06 pm
Die Die Die!!
This Might be a Stupid Question but What Are The Differences Between the Makes
PostPosted: Wed Feb 15, 2006 2:09 pm
could be anything really.
different parts...
Image Image
PostPosted: Wed Feb 15, 2006 2:48 pm
only had mk1 and mk2 in Australia and i guess apart form some trim and wiper things was the introduction of the all synchro box in the mk2 and the 1100 engine instead of the 998 in mk2 (mini K instead of deluxe) and then the clubmans for a couple of years before Leyland renamed it the Leyland Mini
PostPosted: Wed Feb 15, 2006 2:55 pm
Did we really have the mk2 here like the Pom's did ? Mk1 is like our early 850's with the sliding windows , external hinges and floor mounted started . Mk 2 I think in ENglish circles is their windup window's(without 1/4 vent's) while still having external door hinges (ok ,I guess our's was a localised version of the mk2) . Mk 3 had the internal hinges , wider and higher rear windscreen , higher side windows etc . Then there were several more mk's in subsequent years and don't know where they ended .
PostPosted: Wed Feb 15, 2006 3:05 pm
our mk 2's were the wind up with quarter window jobbies, weren't they?
PostPosted: Wed Feb 15, 2006 3:06 pm
The British cars were:
mk1= our 850.
mk2= bigger rear window, and other minor changes
mk3= change from sliding windows to windups and internal hinges. (change happened in 68 I believe). Also had larger rear side windows, and exterior changes like the grille.
mk4= the clubby
mk5= cars built after the clubbies were dropped. Also has 8.4s standard.
mk6= era for SPI engines
mk7= door strengthening, airbag and MPI engines.
PostPosted: Wed Feb 15, 2006 3:12 pm
Mk5's also had softer compound rubber cones , very comfy , especially if you had heaps of extra weight from soundproofing . The cones by themselves were still an improvemnet on the earlier ones .
PostPosted: Wed Feb 15, 2006 3:15 pm
Die Die Die!!
since the clubby is older it doesnt make much sense to have external hinges again...
PostPosted: Wed Feb 15, 2006 3:20 pm
Only had external hinges in Australia.
Britans clubbies were equivilent of mk 3s except for the front.
PostPosted: Wed Feb 15, 2006 3:23 pm
Die Die Die!!
bummer.... :(
PostPosted: Wed Feb 15, 2006 5:36 pm
Australia only had mk1 and mk2 and all this crap about england has no bearing on minis made in Australia, so unless your looking at imports forget about all the UK stuff :D our mini's are unique to Australia
PostPosted: Wed Feb 15, 2006 5:48 pm
Die Die Die!!
tis a shame i would have like internal hinges .. they look real nice :)
PostPosted: Wed Feb 15, 2006 9:05 pm
theres plenty of them at brickworx anyway if you want a roundy.. and yes internal hinges are HEAPS better,
the stupidity of retaining external hinges is all part of the reason why leyland went under
PostPosted: Wed Feb 15, 2006 9:20 pm
Die Die Die!!
yeah but brickworks would want an arm and a leg...
PostPosted: Wed Feb 15, 2006 9:23 pm
prices start at a very reasonable amount
Users browsing this forum: Majestic-12 [Bot] and 88 guests
