It is currently Mon Jul 14, 2025 3:06 pm
 Post subject: Timing
PostPosted: Mon Feb 20, 2006 12:37 am
how do you set the timing on a 998, it overruns after ignition key is turned off
1977 Clubman
PostPosted: Mon Feb 20, 2006 1:12 am
Die Die Die!!
mine does too on a 1100 u need a timing light...
PostPosted: Mon Feb 20, 2006 5:02 am
This mostly happens because the ignition timing is wrong for the fuel type, causing more throttle opening at idle to make the engine idle OK. You need less throttle angle and more ignition timing at ilde to stop the problem (all other things being Ok - like spark plugs for instance). Modern unleaded fuels are crap so the manual settings are ineffective and obsolete. KC
Tuning should always be a compromise between what is possible and what is necessary.
www.calverst.com
PostPosted: Mon Feb 20, 2006 6:02 am
waht keith siad is true, i would also check the idle and fuel mixtures as timing is only one part of the equation and if your idle is too high or its running too rich it will also run on a fraction.
many different things can cause this but get it onto a dyno is the easiest way to getting it set up correctly, that way you will know its good.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Mon Feb 20, 2006 5:12 pm
how much do you reckon it costs to go on a dyno and then get it tuned
1977 Clubman
PostPosted: Mon Feb 20, 2006 5:54 pm
Just back off the idle setting on the carbs to mae it idle lower, check your points gap is sweet & then re-time the ign at that ...& then see what happens you may even have to drop the idle setting some more after that.
