It is currently Mon Aug 04, 2025 10:32 am
 Post subject: Maniflow Extractors
PostPosted: Sat Feb 25, 2006 1:17 pm
Is there a trick to fitting Maniflow 3 into 1's while the engine is in? I've been trying for half an hour and the dmned thing just does not want to cooperate. :x
Any ideas?
Dan
Margaret - 88 Rover
PostPosted: Sat Feb 25, 2006 1:35 pm
Bonnet has to be off, release the steady bars from the motor, remove the bracket from the themostat to radiator. You then have to pull the motor as far forward as you can to S-Q-U-E-E-Z-E them into place - also remove the studs for the head - it gives you that little bit more room
The only way to get them on...good luck
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
PostPosted: Sat Feb 25, 2006 1:47 pm
Cheers Rob. Mary and I were about to have words.....
I'll let you know how I go.
Dan
Margaret - 88 Rover
PostPosted: Sat Feb 25, 2006 2:54 pm
Also try putting the seperate centre runner in first then the 2 into 1 second.
From your view the middle pipe runs down the LHS and the other to the right.
PostPosted: Sat Feb 25, 2006 3:13 pm
If they were LCB Maniflows that would work a treat - the 3 into 1's are all welded together I thought. In any case they are a pain in the butt!!!...lol
Hooroo
Rob Forsyth
Miniot!!
Rob Forsyth
Miniot!!
