It is currently Thu Jul 24, 2025 11:29 am
PostPosted: Mon Feb 27, 2006 9:56 am
i've talked about this before but here it is, i will try to describe a noise i hear when throttle is pressed.
when idling - no noise
when foot off throttle - no noise
when i apply the throttle, only when moving i can hear a noise that could be a drive shaft bearing or rubbing as it turns. I asume its a drive shaft cos it only happens when you press the throttle to drive!, hope you're still with me?. it sounds like its coming from centre to drivers side underneath the motor, is there any simple tests i can do to find out what it is ?
Please help :?
1977 Clubman
PostPosted: Mon Feb 27, 2006 10:04 am
Please help :?
sounds like the noise i was getting before my car threw one of its U bolts...does it make the noise in all gears under power? coz mine didnt make any noise (or atleast not enuff to hear) when i was cruising in 1st...which is what i had to do when the u-bolt eventually gave up the ghost on the freeway :) was exciting...crunch crunch crunch...bang bang crunch bang...uh-oh...better pullover :P
Bling me up Scotty!
PostPosted: Mon Feb 27, 2006 2:24 pm
Have you given everything it's regular greasing?
PostPosted: Mon Feb 27, 2006 4:46 pm
i once had a funny ratle underneath my mini, found out it was an exhaust bracket wobblying up and down the exhaust pipe, on my way to school the next day to fix it, it fell off :shock:
(ok mabey i am way off, i just wanted to post this pic again. he he he :lol: )
PostPosted: Mon Feb 27, 2006 5:05 pm
Where is the U Bolt ? any pics
Thanks
1977 Clubman
PostPosted: Mon Feb 27, 2006 5:09 pm
Not sure if everything is greased on the drive shaft - not sure how to do it ?
again pics would be excellent
Thanks
1977 Clubman
PostPosted: Mon Feb 27, 2006 5:27 pm
Thanks
they connect the drive shafts to the outputs coming out of the differential...there are 8 of them in total (4 on each side)...dont have any pics of it assembled...got pics of it in pieces if you wanna see that :P
differential end:
driveshaft end:
Bling me up Scotty!
PostPosted: Mon Feb 27, 2006 5:31 pm
You'll need a grease gun and a workshop manual.. Any decent mini workshop manual should have diagrams of where each grease nipple is.
PostPosted: Mon Feb 27, 2006 10:21 pm
Thanks for the pics - very helpfull
I feel more confident now.
1977 Clubman
PostPosted: Mon Feb 27, 2006 10:29 pm
just hope it helps...i know how it feels to have a car thats not behaving itself :P
Bling me up Scotty!
PostPosted: Tue Feb 28, 2006 9:55 am
Flicking through the haynes manual last night and found that it could be the final drive gear/bearing etc. Please tell me that this can be fixed with engine in :?
in the manual they call the noise
" noise on drive, quiet on overdrive" - does this mean quiet when you take your foot off the throttle ?
thanks
1977 Clubman
PostPosted: Tue Feb 28, 2006 9:59 am
ANything internally in the gearbox is 99.9% only fixable with the motor out and motr/gearbox split . Is there anyone over in perth that can have a look at this and see what it is for Sean , he'll be a nervous wreck before he sorts it out at this rate . Basically I think you need someone who know's mini's to look at it and find the problem , there's only so much you candescribe in writing when it comes to mini noises .....
PostPosted: Tue Feb 28, 2006 10:08 am
Nope. Big job - wouldn't tackle it myself!
Yep. When the car is pushing the engine, rather than when the engine is driving the car.
Before pulling the engine & gearbox out, rule out the other things suggested here already, especially the driveshafts/joints. Good Luck!
Is there anyone who could come and look at it ?, I'm in Wanneroo
that would be sweet
1977 Clubman
PostPosted: Tue Feb 28, 2006 10:09 am
PM sent
Users browsing this forum: Bing [Bot] and 83 guests
