It is currently Sun Jul 13, 2025 7:03 am
 Post subject: door trims
PostPosted: Mon Feb 27, 2006 3:32 pm
what is the best glue to use when i do my vinal door trims on to mdf
PostPosted: Mon Feb 27, 2006 3:45 pm
Contact adhesive like quickgrip and get it from building supplies rather than from KMart or Mitre 10.
Also rather than using MDF consider using thin plywood or masonite(plywood is better but harder to work with IMO) as these are tough and have better water resistance when water gets down your window sills and sits in the door pockets :wink:
Roads need more corners
PostPosted: Mon Feb 27, 2006 3:51 pm
yeah kwikgrip works a treat
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
