It is currently Wed Jul 16, 2025 6:39 pm
PostPosted: Sun Feb 26, 2006 10:14 pm
Can anyone tell me the details for this cam? ive searched thru my reciepts and have found that the cam was purchased from Northern Mini Parts. It seems to be a WADE CAMSHAFT as the grind number was written on a wade docket, with the grind number '104'.
Much help needed as i will need to 'dial' in this cam for another block im wanting to install it to.
Thanks
Image Image
PostPosted: Sun Feb 26, 2006 10:38 pm
I won't be much help, but I remember this cam as a bit of a HOT road cam from some years ago. I had one in a Mk 1 Cooper and really liked it then.
PostPosted: Sun Feb 26, 2006 10:49 pm
that sounds good. i knew it was a hot cam but i dont know anything about it, like the power band or anything. i wouldnt mind knowing if someoen does, how it compares to something say like that RE-13 that docs always ranting on about.. :lol:
Image Image
PostPosted: Mon Feb 27, 2006 6:08 am
It's in here somewhere if you can navigate the crap site....
http://www.wadecams.com/
I have a Tighe 104 in Barney, it's a lot tamer than an RE-13. :wink:
http://tighecams.com.au/cars.htm
PostPosted: Mon Feb 27, 2006 7:57 am
The wade 104 is exactly what I have in my van.
I have the specs for it somewhere if yoyu get stuck. As I recall the exhaust is the same timing as the 731 works grind, but the lift and inlet timing is different.
Nice mid-range road cam, pulls from 2,000 to 6,000 in my 1132cc with a 12G295 head. Runs out of puff at 6,000, but maybe that's because it's a 1098 crank. :)
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Feb 27, 2006 11:14 am
that sounds awfully familiar, 6k is high gear changing point in 3rd from experience :lol: . But im pretty sure its a wade, i checked the site - yes, its fackin sh*thouse, but i downloaded this program, to do with all their profile grinds i put in the number, it finds a close grind, then u choose the make of the motor, and then it has all the details and figures, but im not convinced. chuck those details up if u find em bnicho! 8)
Image Image
PostPosted: Mon Feb 27, 2006 4:28 pm
how tame do you mean doc, like not as hot just mild....
Image Image
PostPosted: Mon Feb 27, 2006 8:08 pm
Hi,
Found the faded sheet of paper hiding the in the pages of How to Modify your Mini.
Wade 104 specs:
Exhaust Timing: 65-25
Exhaust Duration: 270 degrees
Inlet Timing: 25-65
Inlet Duration: 270 degrees
Lift at Lobe .282
Hope this helps.
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
PostPosted: Mon Feb 27, 2006 8:15 pm
Similar on paper (270* duration) but a lot less lift (only .338" at valve advertised with stock rockers, but I measured .320").
So, I put Toyota Corolla 1.46:1 rockers in to assist.:)
<edit> Tighe 104 and Wade 104 appear to be same timing & duration, but have different lift.
PostPosted: Mon Feb 27, 2006 9:13 pm
ahh excellent! thanks doc, and bnicho.
Image Image
