It is currently Thu Jul 17, 2025 11:37 am
PostPosted: Mon Feb 27, 2006 7:30 pm
I went to install my new clutch master cylinder plastic type, to find it wont fit with a tandem brake cylinder, i also have a brand new brake master cylinder(single type), so what i want to know is how to i convert back to the single setup, also on my clubman the brake switch is under the brake pedal, so i guess i dont need the mech type on stop switch, also my tandem master cylinder has a brake fail switch, which i assume i just dont connect up, also do i need the anti lock thing at the bacl of the car. i am confused what i need to do so any help would be great
77 Leyland Clubman
1293cc, LCB extractors, pulsar dizzy (recurved), cooper s disc brakes, 40DCOE Weber
PostPosted: Mon Feb 27, 2006 8:12 pm
You can not legally go from dual circuit brakes to single circuit brakes. It is part of the ADR's.
You would need to change a few brake pipes to change to the single circuit.
PostPosted: Mon Feb 27, 2006 8:27 pm
If it's a 72 Clubby it should have single circuit anyway. So no worries.:)
PostPosted: Mon Feb 27, 2006 8:41 pm
Take a look at his signature 8)
PostPosted: Mon Feb 27, 2006 8:56 pm
Ah, OK. But,, my 77 van has single brakes...:)
Tandem one is BS anyway. Ask Brad....... he had NO brakes at all until he fitted new rear wheel cylinders. :wink:
PostPosted: Mon Feb 27, 2006 9:53 pm
I win..mine is 78' and has a single :mrgreen:
PostPosted: Tue Feb 28, 2006 6:39 am
anyway back to the topic does anyone no the whats needed to do this, could i just join the two pipes that come out of the master cylinder together using a T peice. These two pipes also connect too another valve thing before going to the brakes
77 Leyland Clubman
