It is currently Thu Jul 31, 2025 6:56 pm
PostPosted: Mon Feb 27, 2006 8:50 pm
Hi
Im looking at doing a flip front and was wondering what people were doing with the chassis no:.because all that metal gets cut away or covered up does it have to be stamped some where else .
Also is it all right to move the complience plate somewhere else ????
Thanks
Steven :P
PostPosted: Mon Feb 27, 2006 9:06 pm
resident alien
resident alien
Mine was moved here
PostPosted: Mon Feb 27, 2006 9:09 pm
so the one on your radiator shroud is still there
PostPosted: Mon Feb 27, 2006 9:12 pm
resident alien
resident alien
That is the only plate I have
PostPosted: Mon Feb 27, 2006 9:20 pm
so dont you have the numbers stamped on the piece of metal next to the top of the radiator????
PostPosted: Mon Feb 27, 2006 9:25 pm
resident alien
resident alien
Not that I can see
PostPosted: Mon Feb 27, 2006 9:29 pm
Does anyone know what the number is for do i need it???????????????
PostPosted: Mon Feb 27, 2006 9:49 pm
The number on the radiator shroud (the location moved over the years) should be the body number or vin , an inspection station will look for it when they do your rego inspection and check it matches with the build plate or compliance plate depending on the year of manufacture . As I said though , the location of the number was on the radiator panel or on the firewall so as long as the inspector finds it in one of those spots they should be happy . I'm not suggesting you move the number but so long as the number is on the car in a spot where they normally are then you'll be fine ......
PostPosted: Mon Feb 27, 2006 9:51 pm
I think it's the chassis/body no. It should be on the VIN plate as well..not sure whether you need to keep both..
PostPosted: Mon Feb 27, 2006 11:34 pm
Must be stamped onto a non-removable body panel
i.e. not riveted on, and not on a bolt on panel
It's on my "To Do" list ...
PostPosted: Wed Mar 01, 2006 3:38 pm
Do you know if i can do it myself or do i have to get the rta to it .????????????
PostPosted: Wed Mar 01, 2006 4:08 pm
Have it stamped before you front up for inspection
you will only get hassles otherwise :(
PostPosted: Wed Mar 01, 2006 4:22 pm
Ive already stripped it down to a shell :x
PostPosted: Wed Mar 01, 2006 4:47 pm
Borrow a set of punches from someone and do it yourself.
I've got a set here, but it's a bit of a long drive :)
PostPosted: Wed Mar 01, 2006 4:55 pm
so you i can do it my self
not that i dont trust you but i might just double check tomorrow with the rta, there a bit stricked in he ACT :D
Users browsing this forum: Bing [Bot] and 93 guests
