It is currently Wed Jul 23, 2025 11:29 pm
PostPosted: Tue Feb 28, 2006 4:47 pm
These look pretty handy:
http://cgi.ebay.com.au/PORTING-TOOL-x3-LONG-SHANK-Die-Grinder-head-work_W0QQitemZ4615207160QQcategoryZ43808QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
But I don't want to fork out $150 for em.. Anyone know if there is a cheapo version of these available? I can make do with what I've got, but something like this would make it quicker..
PostPosted: Tue Feb 28, 2006 6:14 pm
Can't believe that price, $150 indeed! :lol:
I find the shorter carbide ones are pretty good, I paid $20 or $30 each a while back.
If you buy these long ones, don't run them fast- it's very dangerous. They can whip off centre and break your air grinder or dremel, or even injure you. :shock:
PostPosted: Tue Feb 28, 2006 6:18 pm
I have a couple of the shorter carbide ones... they work excellent! Just thought the longer ones would be quite handy, except paying an extra $100 for a longer stem seems unresonable..
When you say not too fast, what speed are we talking? Not above 15,000?
PostPosted: Tue Feb 28, 2006 6:22 pm
I'd limit it to 7000. It will still cut OK at that.
PostPosted: Tue Feb 28, 2006 7:38 pm
You would run these in a dremel? :shock:
I thought it would burn them out? Does it work well?
PostPosted: Tue Feb 28, 2006 7:45 pm
I don't think they'd fit in a dremel would they? Probably need a 1/4" chuck.. Dremel's are pretty tough though, I've put mine through a lot.. But I've got a electric die grinder aswell.
Is there any advantage between electric or air dir grinders?
PostPosted: Tue Feb 28, 2006 8:52 pm
When I say `Dremel' I mean a bigass one like GR uses.. not sure if that's what brand it is.
Mine is an Ingersoll Rand die grinder (24,000 rpm)- a bit slow for dental work :lol: but it removes metal way faster than my Black & Decker drill used to!
 Post subject: torque
PostPosted: Tue Feb 28, 2006 9:47 pm
The electric one is the bees knees for cast iron work as it has heaps more torque then the air die grinder.
Carbide tools are for cutting not grinding and if you dont apply enough pressure to the cut it will rub the edge off the tools in no time.
For porting an 80 or 40 grit flap sander can give very nice removal feel and speed. $150 will get you a lot of sanding pads
Users browsing this forum: Bing [Bot] and 91 guests
