It is currently Sat Aug 09, 2025 10:13 am
 Post subject: HAD TO HAPPEN !!!
PostPosted: Thu Mar 02, 2006 9:11 am
blue slip today and i had to drive approx 10 ks to get there.
ok well this mornin i statred the car up and started reversing down the driveway...then i stalled it at the bottom.. i went to start the engine up again and it didnt start....
all it made was a click noise. ...
so in the pooring down rain i had to get my mum to push the damn thing so i could clutch start it to take it in to the servo for the blues slip....
i then had to explain to the guy what happened..... aaaaaaaahhhhhhhhh
pretty sure i wont be gettin that blue slip now....
PostPosted: Thu Mar 02, 2006 9:19 am
Trust it to rain, Ironic it only happens when your doing something important
57 Morris minor
88 Rover Mini
PostPosted: Thu Mar 02, 2006 9:47 am
sounds like a loose battery terminal
PostPosted: Thu Mar 02, 2006 9:59 am
above all days for it to happen.
PostPosted: Thu Mar 02, 2006 10:00 am
It's almost inevitably this with my clubby :lol:
Roads need more corners
PostPosted: Thu Mar 02, 2006 10:03 am
The *click* when you try to start it could be the starter solenoid not engaging or sticking.
I've had and heard of lots of cars doing that. Dad used to keep a special hammer in his Kombi for that reason. Mum would turn the key while Dad would get under the van and tap the sticky solenoid with the hammer to allow it to move. Even my cressida will do the *click* on occasion.
- Simon -
PostPosted: Thu Mar 02, 2006 3:37 pm
looks as if my starter motor is gone.... well thats what the mekanik told me....
failed the blue slip ..
--- need to adjust rear wheel bearings
--- LH uper ball joint needs something
---shock mount on the front need tightenin
--- need new front right shock
---drive shafts are leaking oil
--- ? ? ? ignition key barrel not connected to steering lock ? ? ?
--- and now the starter motor
PostPosted: Thu Mar 02, 2006 3:42 pm
Probably means that steering lock isnt working probably.
eg, even when theres no key in the ignition u can still freely turn the wheel.
No more Minis!......For now.
PostPosted: Thu Mar 02, 2006 4:12 pm
exactly what happened to mine back in 2K4...cost me about $250 to get it done by a sparky...worked fine after that...till something else broke...cant remember what it was :P
Bling me up Scotty!
PostPosted: Thu Mar 02, 2006 6:23 pm
What year is your car?
Is the ignition switch in the middle of the dash or on the steering column?
There is a very good chance that your mechanic is a dickhead. 8)
PostPosted: Thu Mar 02, 2006 6:34 pm
Yep... my 1275 LS used to do it occasionally... then it simply fixed itself and hasn't done it since (touchwood).
PostPosted: Thu Mar 02, 2006 7:12 pm
meeni does that at time, i just remove and then re attach the earth and it seams to fix it
Potato
PostPosted: Thu Mar 02, 2006 8:26 pm
its a 74 clubby????
i will try reattachin the earth..
PostPosted: Thu Mar 02, 2006 8:52 pm
Ahhh , the joy's of owning a mini , clean the battery terminal's , check the earth strap is bolted to clean metal (no corrosion) in the enginebay and tell the mini that if it doesn't behave in a suitable manner before the next inspection then it's going to the wreckers . Alway's worked for me ......
PostPosted: Thu Mar 02, 2006 9:05 pm
yer well if it keeps playin up its going in the for sale section
