It is currently Sun Aug 17, 2025 12:17 am
Post new topic Reply to topic  [ 17 posts ]  Go to page Previous  1, 2
PostPosted: Sat Mar 04, 2006 11:44 pm
thanks heaps for that peoples. Will see how I go tomorrow.....well today now actually-crap, wanted to get an early start on it. oh well
off to NT I go
PostPosted: Sun Mar 05, 2006 7:43 am
I'd buy the knuckle as a kit with the nylon cup and new boot, replace the lot.
You have to wonder what made that ball pin break- maybe the ball has worn thru the nylon cup and into the arm...
I'd check the other 3 corners while you are at it, these knuckle joint kits are cheap.
Then, It might ride level again. 8)
I've only ever seen two break , both clubby fronts , I've been wondering if they had a quality problem at some stage for a brief run or there was something different in the top arm that was changed again .
Users browsing this forum: No registered users and 354 guests
