It is currently Fri Jul 18, 2025 8:52 pm
 Post subject: gti subframe
PostPosted: Sat Mar 04, 2006 6:56 pm
well its basically the same as most of the others that you have seen, except the bar at the front. I chose to bend mine and use 8 c/sunk 12.9 M8 hex screws.
Still need to make the mounts up. more clearance needed for the rear of the g/box too.
but it is progress.....
PostPosted: Sat Mar 04, 2006 8:52 pm
oooOOO purdy...looks alot like JC's :P
no offense or anything but...is it just me or does it look a wee bit on the flimsy side? the one i've got planned sure is ALOT beefier than that...perhaps unnecessarily so :?
Bling me up Scotty!
PostPosted: Sun Mar 05, 2006 1:06 pm
just you I guess.... engineer thinks its ok....
PostPosted: Sun Mar 05, 2006 1:50 pm
Looks like a neat piece of work 8)
I agree that a lot of the others are WAY over engineered!
(I include my own in that category)
PostPosted: Sun Mar 05, 2006 3:33 pm
Looks great , tidy work ....well done.
Is my subframe the only one with a removable centre crossmember? i notice the 4fte's dont use one either?
PostPosted: Sun Mar 05, 2006 6:47 pm
Looks good, Inazuma be careful not to overdesign and end up having unnecessary weight.
Dan
PostPosted: Sun Mar 05, 2006 10:38 pm
my front bar is removable, makes it easier to install im my case... (c/sunk screws) lucky that the oil filter is not that hard to remove either.... I don't need to remove the bar to remove the filter.
PostPosted: Mon Mar 06, 2006 8:16 am
Dan
what size members did you use dan? i am looking at 50mm x 50mm RHS with 5mm walls...spose i could ask the engineer...
Bling me up Scotty!
PostPosted: Mon Mar 06, 2006 8:21 am
Ina, you;ve got to remember how cramped for room it is in there aswell. When I read you "50 * 50" comment i got my ruler out and said to myself ">>ck that's huge".
Anyway, good work Mano, Ron will be pleased to see his brainchild populating allover the country.
PostPosted: Mon Mar 06, 2006 8:25 am
40x40 was my other option :) just thought that it might not be enuff...
spose 50x50 is a bit on the massive side...
Bling me up Scotty!
PostPosted: Mon Mar 06, 2006 9:48 am
Don't go over the top with 5.0mm Wall Thickness
A little bit of gusseting in the corners would be a lot more effective :idea:
PostPosted: Mon Mar 06, 2006 9:51 am
well i was gonna gusset pretty much every corner that formed a 90 degree...which is a fair few...i havent discussed any of this with the engineer as yet...i wanna make the jig first...then i will have a better idea of what i am gonna be doing...all i have at this stage is a few rough sketches and a mental image of how i want the finished product to look...
PS sorry for hijacking this thread :P
Bling me up Scotty!
PostPosted: Mon Mar 06, 2006 10:04 am
Die Die Die!!
heres something to compare to guys...
http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&item=8039363145&rd=1&sspagename=STRK%3AMEWA%3AIT&rd=1
PostPosted: Mon Mar 06, 2006 10:13 am
hot DAMN! that thing is sexy...not the kinda thing i have in mind...that thing's a bit TOO radical in terms of its deviation from stock...i am aiming for something more like this:
Bling me up Scotty!
PostPosted: Mon Mar 06, 2006 10:15 am
Die Die Die!!
ahh yeah nice, i guess the one i posted is fair overkilll.. would a motor like that be more fuel efficient ?
