It is currently Sun Jul 27, 2025 2:47 pm
 Post subject: another problem........
PostPosted: Mon Mar 06, 2006 6:58 pm
my car will now not start.... it just keeps turnin over and wont start.... we even clutch started it but it just dies...????
it seems asthough im just getting problem after problem and am getting real annoyrd....
someone please help....
ideas and theorys greatly appreciated...
PostPosted: Mon Mar 06, 2006 7:03 pm
check if you are getting fuel, spark and then if both are good it is timing
it sounds like the problems i am having with cracker and that is fuel pump
take the fuel line off the carby andhave someone turn it over and see if fuel is getting up there
if not work your way back down the fuel line to find the problem
PostPosted: Mon Mar 06, 2006 7:08 pm
we sprayed some of that "start ya bastard" in the carby and then tryed to start but she didnt?????
PostPosted: Mon Mar 06, 2006 7:20 pm
sounds like your getting no spark :?
PostPosted: Mon Mar 06, 2006 7:33 pm
Take the distributer cap off , turn the ignition on (so the lilghts on the dash come on) and open the points using something non conductive (otherwise it might bite you) , if you see a spark between the contacts of the points than you have power to there . Next take a plug out , hold it against the metal of the head and have someone try and start the engine , if you had spark at the points (last test) but not at the plug then adjust the points gap . If it still doesn't spark at the plug check your rotor button for corrosion , check the little carbon rod is still in the centre of the dist cap that touches the rotor button and check your leads . Also check the coil low tension cables ("normal" wires ) are attached as well as the coil lead .
Does the ign light come on when you turn the ign on ?
PostPosted: Mon Mar 06, 2006 7:52 pm
yer the ignition light comes on...
i spoke to a friend and we think i might have ran out of fuel... well enough not to get pumped to the engine. our drive way is on a far angle. it stalled and made like a puff... i have since poured 5 more litres of fuel in... but still didnt start.....
sorry that it seems im always havin problem.....
cheers for the help
PostPosted: Mon Mar 06, 2006 8:57 pm
Well , evein if it was out of fuel I'd imagine with an ether spray like start ya bastard it'd fire and run till the motor used the ether . You said it tried to start did it run but die or cough and splutter ? Have you got an electirc or mechanical fuel pump ? If you've checked the spark and it's working then pull off the fuel line to the carb and turn the ign on briefly , if it's electric or crank it slightly if it's mechanical and see if fuel comes out , the pump may have been on the way out and is having trouble pushing the fuel up from empty .
PostPosted: Mon Mar 06, 2006 9:53 pm
i was having the same prob had to get new ignition barrell was good for week but its going back down the same path putt putt then backfire then no start
PostPosted: Tue Mar 07, 2006 9:32 am
just installed a whole new ignition barrel ??? like 2 days ago
PostPosted: Tue Mar 07, 2006 9:49 am
This will probably sound really obvious but did it run before and since you fitted the ign barrel ?
PostPosted: Tue Mar 07, 2006 10:34 am
G'Day Harvey69,
Change your ignition coil, they can still give a weak spark in open air but nothing when under compression inside your cylinder.
Over 1,000,000Km, but now my retirement restoration project
PostPosted: Tue Mar 07, 2006 1:23 pm
ok will install a new ignition coil..... the ignition barrel works because i started it in the garaged .... it just randomly stalled.
PostPosted: Tue Mar 07, 2006 1:26 pm
but i am unable to clutch start it either.......
it just like trys to start but just dies???
is it not able to get petrol to the engine or is that usually because of electrics
PostPosted: Tue Mar 07, 2006 1:31 pm
That could be either still , do the checks outlined above and it'll tell you which way to look , either fuel or electrical . Otherwise we'll just keep suggesting you replace things which will get expensive in the end , find which system is having problems and then we'll have a better idea .
PostPosted: Tue Mar 07, 2006 1:40 pm
Have you checked the timing :?: As you cannot get it going at the moment you will probably need to staticly set the timing and then use a timing light to check it once you get it going.
If the timing/ distributor hasn't been changed since it went don't touch the timing, it will just make more problems.
Do check you have the plug leads on in the right order though firing order 1,3,4,2 with the dizzy rotating ANTI CLOCKWISE.
You are now getting fuel into the fuel bowl of the carby :?: So it's not a fuel pump problem :?:
How to set you timing close enough staticly...
rotate the engine to Top Dead Centre on no 1 cylinder(a pencil or bit of wire down the spark plug hole will help here) with both the exhaust and inlet valves closed. At this point if you take the cap off your distributor the rotor should be pointing to the lead running to spark plug no 1. If this is not the case rotate the dizzy until the rotor is pointing to the contact for spark plug no 1. should normally be pointing to about 1 o'clock I think :?
Generally timing way out or plug leads in the wrong order will give spluttering and kick back type symptoms
Roads need more corners
