It is currently Tue Jul 22, 2025 5:33 pm
 Post subject: Pulsar Dizzy question
PostPosted: Tue Mar 07, 2006 2:39 pm
NAV-MAN
I have gotten a pulsar distributor and modified it to fit no worries.
When i hook up the blue wire to -ve and the black with white trace to +ve i get no spark. But if i put both of them on the +ve side it fire no worries.
Is there something wrong here?
It still runs better than the lucas one did.
PostPosted: Tue Mar 07, 2006 2:44 pm
OK coil is hooked up with power to + and - to earth
then dizzy blue wire to coil -ve
and dizzy black/white wire to coil +ve
:wink:
PostPosted: Tue Mar 07, 2006 3:18 pm
NAV-MAN
:wink:
ah HA! all good now thanks awdmoke
PostPosted: Tue Mar 07, 2006 3:21 pm
Got mine around the wrong way before too :oops:
It's called "learning from your mistakes" :lol:
PostPosted: Tue Mar 07, 2006 3:34 pm
"learing from your mistakes"
I just can't help but to ask this but are you just an old learer from way back awdmoke??????
PostPosted: Tue Mar 07, 2006 3:37 pm
:oops:
Just learned that Smokie is still an old smart arse! :lol:
PostPosted: Tue Mar 07, 2006 3:42 pm
You forgot to say old smart arse Mike... :wink:
PostPosted: Tue Mar 07, 2006 4:28 pm
NAV-MAN
I have another problem now it starts cutting out after 1min at 100km/h
if you let it idle for a while all is good again.
You can putt around with no problems,it's just at 100km/h or there abouts
<edit> all sorted now twas a earthing issue it was. 8)
PostPosted: Wed Mar 08, 2006 8:59 am
what differences does the pulsar dizzy make cause thinking of changing mine soon
PostPosted: Wed Mar 08, 2006 10:37 am
Reliability
+ you get a better "fatter" spark, and never have to change a set of points again :D
PostPosted: Wed Mar 08, 2006 10:54 am
Less timing scatter more accurate,
it's not Lucas(Oh you said reliability :D )
Roads need more corners
