It is currently Wed Jul 30, 2025 11:52 am
PostPosted: Wed Mar 08, 2006 11:25 pm
Can anyone post a full set of instructions to fitiing sportspack arches ('93 mayfair currently on 12 by 4.5's), including cutting of the body work and fitting. Thanks.
Or alternatively, how much does it cost approx to get a mini shop do it for me??
Cheers.
PostPosted: Thu Mar 09, 2006 5:21 am
In the Miniworld - Keeping Your Mini Alive 5 issue, they give full step by step instructions on fitting the arches, no longer for sale, you will also need a set of templates which show you where to drill and cut the body, I had the body work done for the arches by the panel shop while the rest of the work was being done.
I could probably photocopy the section out the mag, but won't be until the weekend..
PostPosted: Thu Mar 09, 2006 5:45 am
If you want the templates, look on eBay UK - there's always some for sale on there quite cheaply 8)
Bob Slattery
PostPosted: Thu Mar 09, 2006 3:12 pm
I have them as well if you want to borrow them. Should be easier to fit on a rover than mine, no external hinges.. After all thats what they were designed for..
Send me a PM if your interested.
Mat
