It is currently Wed Jul 16, 2025 4:15 pm
PostPosted: Mon Sep 27, 2004 4:05 pm
G'day all,
Just after a little advise, i'm putting a 1.5"su on a 998 (12g295 head and extractors if this makes any diff)
The question i have is, what air filter setup would be best?
i have two shells, an 850 with a round hole behind speedo and a Deluxe with the hole covered, the 850 is the shell being used, which would mean i have enough room for a big setup but i am a little worried about noise and i guess if it was to backfire??
so i really have a couple questions:
1) Is ok to leave hole there? ifso whats best setup if room not a prob?
2) If its best to cover hole, whats best setup for limited room?
any help on this will be very appreciated
PostPosted: Mon Sep 27, 2004 4:14 pm
If you leave the hole open, I'd use an HS4 ramstack and a Unifilter sock. But it will be noisy.. :wink:
pic here- http://www.minimania.com/web/Item/C%2DA ... Detail.cfm
If you close it off, a K&N cone filter or a Lynx Ramflo. Either of these should have a stubstack inside with a radius entry to the carb.
K&N still make them, I think.
PostPosted: Tue Sep 28, 2004 7:25 am
Kurross wrote:
G'day all,
Give Midel a call or Email 9759 5598 or [email protected] and speak to bill. They are in Lakemba the better side of. :P
PostPosted: Tue Sep 28, 2004 8:15 pm
Midel's website-
http://www.sumidel.com/
It's more useless than their old one was, IMO... :cry:
PostPosted: Tue Sep 28, 2004 11:08 pm
Yer doc, Phone Number and Email address, I love my Gong freinds
PostPosted: Wed Sep 29, 2004 7:16 am
thanks for that, i think i'm gunna go for the open hole setup to start with, and if its too anoying cover it up and put the cone one on.
i have sent a email to Midel requesting pricing on a HS4 ramstack and a Unifilter sock (also a needle and spring to suit)
Thanks again
PostPosted: Wed Sep 29, 2004 3:07 pm
if anyone interested this is the reply i got:
Dear Sir
Ram tube is $44.00, sox $24.00, Needle $14.30, Spring $4.40, $8.50 delivery.
Currently out of stock of tube ,approx 3 weeks.
Regards
"For all your SU carburettor requirements"
Midel Pty. Ltd.
4 Frazer Street, Lakemba
N.S.W 2195
Australia
P: 61 2 9759 5598
F: 61 2 9758 1155
E: [email protected]
PostPosted: Thu Sep 30, 2004 1:56 pm
When I was playing with an HS4 carb, I had a ram tube and sock. It wasn't particularly noisy, and I have a hole in my firewall (If you want noise, try a Weber/Dell'orto, ramflo air filter, with a hole in the firewall and no dashboard installed. That sounded awesome!!). Better than a ramflo or K&N tapered job in my opinion, as it is cheaper and probably flows better.
That's a pretty good price for a tube, but i payed less for a Redline sock.
