It is currently Tue Aug 12, 2025 10:06 pm
 Post subject: Wireing
PostPosted: Sun Mar 12, 2006 2:49 pm
I have installed a Timex Tacho and Temp Gauge which did not come with Wireing Diagram :evil: Tacho Works no troubles but I just get the temp gauge to work properly When the Radiator is at 60 the Gauge is at 100.
Lights are always on when Ign is on and when the Ign is Turned on Both bounch all the way to the top then settle back (well temp back to 100)
Tacho has yellows red green and black (red to the fuse box Ign yellows to lights and green to coil)
Temp has yellow red Blue and Black (red to fuse box ign Yellow to lights and blue to Temp Sender)
any ideas
PostPosted: Sun Mar 12, 2006 2:50 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
is the temp gauge farinheight or celcius ???
makka
PostPosted: Sun Mar 12, 2006 2:59 pm
Did the gauge come with its own temp sender or are you using the standard mini one? It is possible that the Temp gauge operates on a different Ohm range than the standard mini sender.
PostPosted: Sun Mar 12, 2006 3:05 pm
I believe it C as it only goes to 150.
Normal Mini Sender..I don't believe it came with one..as I got it for nicks as I delivering a Motor
PostPosted: Sun Mar 12, 2006 3:15 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i agree with toolman get the correct sender for it jimbo
makka
PostPosted: Sun Mar 12, 2006 3:18 pm
Bugger all chance in that.. as I cant find anything on the net for them..
Hmm I'll have to look some more maybe
Any idea about the bounce when ign come on?
PostPosted: Sun Mar 12, 2006 3:23 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
i think that is the gauge resetting it self my tach dose that as well
makka
PostPosted: Sun Mar 12, 2006 4:39 pm
Jim, if you can't get the right sensor,
try putting a resistor in parallel with the sensor to drop it back down the scale. Trial & error or use a variable resistor (trimpot). :idea:
PostPosted: Sun Mar 12, 2006 5:00 pm
Bahahahah..yuo lost me
Joining wires, soldering and working out where they go is about it for me
PostPosted: Sun Mar 12, 2006 5:30 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
what ya rekon 2 k variable mike ????
if so i sould beable to sort it for you jim
makka
PostPosted: Sun Mar 12, 2006 7:29 pm
Probably not a bad guess to go with makka - give it a try on max resistance, then turn it down to see if you can get the gauge in the right range.
Let us know how you go :wink:
PostPosted: Sun Mar 12, 2006 7:34 pm
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
no worries might get a 5k for safty
jimbob when ya want me to do it for you
makka
PostPosted: Sun Mar 12, 2006 8:49 pm
hehe..I know what a resistor is but have no idea what I would be looking at
PostPosted: Mon Mar 13, 2006 8:56 am
I DWIVE A BIG TWUCK
I DWIVE A BIG TWUCK
nah we will get a VR and put it in line that way we can adjust it toll it reads correct
makka
PostPosted: Mon Mar 13, 2006 6:06 pm
Where d I get one from mate
Users browsing this forum: 1071 S, Bing [Bot] and 309 guests
