It is currently Sun Aug 17, 2025 12:40 pm
 Post subject: Un-velcome Vheel Vobble
PostPosted: Mon Mar 13, 2006 4:40 pm
Hi all... i've been getting vibrations on steering to the anti-right and i've been fossacking around under the car today and it looks like the drivers side steering arm is a bit loose...
would this account for wobble on left turns on acceleration?
Aaaaannd... can you change a steering arm without taking the rack out?
ta
PostPosted: Mon Mar 13, 2006 4:43 pm
resident alien
resident alien
Sick sick man!!!
PostPosted: Mon Mar 13, 2006 4:51 pm
i knew i'd have no hope at getting a straight answer with the new sig.. :)
PostPosted: Mon Mar 13, 2006 7:03 pm
wheres your makeup?
PostPosted: Mon Mar 13, 2006 7:19 pm
resident alien
resident alien
He's scary enough without it!
PostPosted: Mon Mar 13, 2006 9:04 pm
DTrain wrote:
wheres your makeup?
That's with makeup - you should see him without it :shock:
PostPosted: Mon Mar 13, 2006 9:05 pm
so how's about the question?
feel free to pm me about how funny i am... i'm trying to get some info...
PostPosted: Mon Mar 13, 2006 9:11 pm
cush wrote:
Hi all... i've been getting vibrations on steering to...
Tell me... are they GOOD vibrations? :roll:
PostPosted: Mon Mar 13, 2006 9:19 pm
nah n'nah n'nah nah n'no
PostPosted: Mon Mar 13, 2006 9:21 pm
good good vibrations...
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 13, 2006 9:22 pm
oom bop bop good vibrations.
PostPosted: Mon Mar 13, 2006 9:26 pm
the new ausmini band 8)
-jamie-
1963morris 850
1965 solid side van
1994 rover racecar
PostPosted: Mon Mar 13, 2006 9:46 pm
yeah, just make sure that "IF" you swap the arm out for another one that it`s the matched arm to the same as the other side many different arms around & don`t want to mis-match em,,,yukky steering then, (check the part numbers on em, should be an odd number (L/H) & the very next even (R/H) one would make up the pair) probly need to re-new the dowels in there too & locktite em all in & crank up the torque on the bolts & locktab em down etc
& yeah, you`re funny
you should be on stage...
PostPosted: Mon Mar 13, 2006 10:35 pm
thanks.. cheers for that, matt.. so what's the availability of the arms? hens teeth or dime-a-dozen?
oh.. and also.. you once (ages ago)mentioned the easy way to remove the radiator.. care to list it again.... maybe poeee can make it a proper HOW TO:
PostPosted: Tue Mar 14, 2006 8:43 am
Yeah, the first one out of town preferably... :wink:
Users browsing this forum: No registered users and 388 guests
