It is currently Sat Jul 19, 2025 10:02 am
 Post subject: 13's offset
PostPosted: Mon Mar 20, 2006 4:06 pm
Die Die Die!!
is there any easy way of explaining how much u need to chop for 13's to fit a Morris mini ?
PostPosted: Mon Mar 20, 2006 4:20 pm
Buy My 13's - they fit with no chopping (just stocky flares and Hi-Los)
Bob Slattery
PostPosted: Mon Mar 20, 2006 4:22 pm
Die Die Die!!
how is that the case ?
PostPosted: Mon Mar 20, 2006 8:54 pm
The lower your car is, the more metal you need to remove.
The wider the wheel is, the more metal you need to remove.
The greater the offset, the more metal you need to remove.
The basic rule is: remove 1 inch of steel from the front half of the front wheel arch and blend it into the original arch just behind the top of the arch. At the front, the cut will almost meet with the bumper bar mounting flange.
More info:
http://www.ausmini.com/forums/viewtopic.php?t=1887&highlight=cutting
http://www.ausmini.com/forums/viewtopic.php?t=1223&highlight=cutting
http://www.ausmini.com/forums/viewtopic.php?t=871&highlight=cutting
http://www.ausmini.com/forums/viewtopic.php?t=303&highlight=cutting
PostPosted: Tue Mar 21, 2006 1:53 am
Die Die Die!!
ok no worries :) cheers for the help.. i might just stick with 12's
