It is currently Sat Jul 19, 2025 5:17 pm
 Post subject: 7 port mini sport
PostPosted: Thu Mar 23, 2006 7:52 pm
hey hey
ive just got my 7 port minisport head. (aka...akm)
does any one know the jetting settings for these heads....
got 40dhla dellortos 544 cam had head modified slightly roller rockers. ect
just basic ball park settings would same me alot on the dyno when i fit it
thanks
daniel :)
PostPosted: Thu Mar 23, 2006 10:49 pm
man i must say that i`ve absolutely no experience with those heads what-so-ever, (Who has here in oz? :-) ) but i`d just bung 2x std mini webber/dellortos on & see what happens
can`t be too far wrong really, probly will want to change maybe the emulsion tubes after the dyno run but can`t see why you`d have to change much else
suck it & see
PostPosted: Fri Mar 24, 2006 1:01 am
Resident Haemorrhoid
Piccies please 8)
mtsmini wrote:
Tombo wrote:
PostPosted: Fri Mar 24, 2006 8:46 pm
find out what jetting they use for datto 1200 or toyota 1200 engines of similar spec with twin 40mm carbs and you would be able to start from there
PostPosted: Tue Mar 28, 2006 3:36 pm
ask minisport they might be able to point you in the right direction.
www.minicranks.com add me to your watch list and come back again soon, under construction.
PostPosted: Wed Mar 29, 2006 3:23 pm
yer ask minisport, or if they are no help try a brittish forum like www.minifinity.com :wink: they might know more as they arent to common out here
Potato
