Hi,
I have a 1275 (1100s based) that is basically freshly rebuilt (new pistons, rings, bearings, rebored 40 thou, reground crank, new oil pump, water pump, reground cam) all done by a professional endgine rebuilder.
What I added was a new ultralight steel flywheel, new (second hand) backing plate and my existing pessure plate and clutch plate (only 5000kms old) All on my old but good cond. gearbox.
It has a really bad vibration all through it, (diagnosed as engine, flywheel etc out of balance, not metal on metal, spent hours going over what it could be with a couple of respected mini people) so;
It is coming out to be stripped down, balanced and reassembled.
My question is;
What should I do with it all stripped down?
Cam change (road use, needs to be traffic jam friendly)?
Diff rebuild (I have the bits, just ran out of time last time)?
Other?
Matt
