It is currently Tue Aug 05, 2025 5:13 am
PostPosted: Sun Apr 02, 2006 4:16 pm
Die Die Die!!
ok im putting the head back onto my mini and evrything is on, but i canf igure out where the throttle return spring goes exactly, cos one way its totally on and the other is fowling with the throttle cable... standard 1100 engine...
PostPosted: Sun Apr 02, 2006 5:35 pm
Die Die Die!!
no one who has a stock 1100 wants to walk outside and take a quick pic of their carby for me ?
PostPosted: Sun Apr 02, 2006 5:44 pm
There is a bracket sandwiched betwwen the carby and the manifold, this bracket has an arm that leads down along the exhaust pipe, it is at the bottom of the bracket that you will find a pinhole where the return spring fits on. :wink:
PostPosted: Mon Apr 03, 2006 7:11 am
The HS4 carb (on 998 Clubby etc) does have that sandwich plate.
Bur early cars with single HS2 carb just had an L bracket on the exhaust clamp, to hold the spring. :wink:
PostPosted: Mon Apr 03, 2006 7:18 am
Die Die Die!!
well at the moment its connected to the top of the carby pivot arm.. and on the bottom is connected to the exhaust/manifold clamp..
PostPosted: Mon Apr 03, 2006 7:25 am
On early cars that is correct. what year is the motor, and what carb is it- 1-1/4" (HS2) or 1-1/2" (HS4)?
PostPosted: Mon Apr 03, 2006 7:26 am
Die Die Die!!
1974 Leyland Mini clubman... stock... so watever stock is.. all i know that it fowls with the accelrator cable when i put my foot down.. causing it to stay on...
PostPosted: Mon Apr 03, 2006 7:34 am
There should be a little metal plate on the throttle lever, next to the cable clamp nuts, that is for the spring. Cable should not foul on it, either the part is missing or cable too long or parts assembled in incorrect order.
PostPosted: Mon Apr 03, 2006 7:38 am
Die Die Die!!
i know the plate your talking bout where do i put the other end once it on that plate cos i put it on there and the exhaist clamp and it held it on....
PostPosted: Mon Apr 03, 2006 7:55 am
the bottom end of spring is on the exhaust plate, if the spring is at an angle undo the exhaust clamp and rotate it on the pipe a bit.
Spring should sit roughly parallel to throttle cable.
PostPosted: Mon Apr 03, 2006 2:50 pm
I'll take a pic when I get home for ya! :D
1975 Leyland Clubman 'S'
1976 Leyland Clubman 'S' *work in progress*
I smile everytime!
PostPosted: Mon Apr 03, 2006 5:14 pm
there you go, if you need more i can always take more happy snaps :D
I smile everytime!
PostPosted: Mon Apr 03, 2006 6:12 pm
Die Die Die!!
this is what mines like atm...
PostPosted: Mon Apr 03, 2006 6:40 pm
i'm not 100% sure, but it looks like the hose is in the wrong spot. can it not be moved
PostPosted: Mon Apr 03, 2006 7:21 pm
is that a heater hose going under your carbie?
I smile everytime!
