It is currently Tue Jul 29, 2025 2:52 pm
 Post subject: Clubby Dashboards
PostPosted: Sun Apr 02, 2006 12:18 am
Hi All , Im intrested in making a clubby dash does anyone have plans for this ! ! ! also I would like to see How MANY DIFFERENT dashboard are out there post some pics up for all to see......
Cheers Monster Mini :D :) :D
DVS K
Toad the Moke
Brutus the Ute
Mean Monster
Purple People Eater
PostPosted: Sun Apr 02, 2006 1:03 am
http://www.ausmini.com/forums/viewtopic.php?t=16979&highlight=interior+pictures
 Post subject: How To....
PostPosted: Tue Apr 04, 2006 3:40 pm
I had had a few PM's asking how I built my dash and if they can get the plans. (I will start this and it will need to be edited when i get how this afternoon as I have images there to put in). BTW thanks to those for inspiration and Marvin for his pm help..
1. download http://www.wannop.karoo.net/mini/dash/y ... 20dash.doc
2. out of a thin piece of MDF (3 or 6mm) cut the above pattern/template (do not include the shallow ashtray) - I used a Linisher (a bench mounted long belt sander) as this got me nice smooth edges it is very hard to get a straight edge with a jigsaw
3. push this in between your top and bottom dash pads (it will not fit as everyone's car is different - using a steel rule measure up and down at various points to that you would need to sand to to make it fit. - (USE VENTILATION PROTECTION - MDF WILL KILL U)
4. trace this template onto a piece of 12mm MDF ... Then fix your tracing up with the measurements you took from step 3. Cut/sand your MDF down to size.
5. fit between your dash pads again and make any alterations from there.
6. put a 45 degree bevel along the sides and top of the back of your panel to make it fit in.
7. ......to be continued in an edit as i need measurments off the mini at home plus thee is a storm coming and i need to get the laptop to the car :D :D :D :D :D
PostPosted: Tue Apr 04, 2006 8:33 pm
High heel ninja
Heres our clubby dash
Doogie
PostPosted: Wed Apr 05, 2006 8:13 am
hopefully this works Im a lil rusty with html
</a><img src="http://i63.photobucket.com/albums/h158/1360LS/1bf003a9.jpg"></a>
PostPosted: Wed Apr 05, 2006 8:14 am
http://i63.photobucket.com/albums/h158/ ... f003a9.jpg
on the right h/s its a 3 gauge setup
