It is currently Sun Aug 03, 2025 6:36 am
 Post subject: What are these ?
PostPosted: Wed Apr 05, 2006 8:15 pm
I found a few of these under some of the value springs. http://www.users.bigpond.net.au/drekkus/
It says on the top "This Side Against Valve Springs"
PostPosted: Wed Apr 05, 2006 10:34 pm
Valve stem seals.. or oil seals..
PostPosted: Wed Apr 05, 2006 10:50 pm
They're metal and were under the valve spring.They were also only under 4 , 3 exhaust and 1 inlet.They almost look like some sort of shim but I can't find anything in my parts book that look anything like them.
I'm trying to work out if I need to put them back on or not.
PostPosted: Wed Apr 05, 2006 10:55 pm
They are valve shims, used to pack the springs up. Used by engine builders to get more valve spring pressure, by compressing the springs to their designed set length.
Maybe those valves where these fitted are sunk further into the head...
 Post subject: careful...
PostPosted: Thu Apr 06, 2006 8:18 am
and you need to be careful when you put the rocker gear back on if the shims have slipped out to one side from under the spring retainer. The post can foul the shim as you are dropping it down :idea:
Users browsing this forum: timmy201 and 101 guests
