It is currently Sun Aug 03, 2025 9:46 pm
 Post subject: Dents
PostPosted: Wed Apr 05, 2006 11:47 am
I have a couple of dents in my roof, nothing major just where people have obviously rested arms. i am painting myself and I am confident with that side of things. Does any one have a step by step guide (easier trhe better :D ) for repair. Would prefer not to take out roof lining. Every time I have tried in the past, I still can see a dent through the new paint.
Help please :D
PostPosted: Wed Apr 05, 2006 12:45 pm
I thought the only way to remove dents from the roof was to take the head-lining out :?
PostPosted: Wed Apr 05, 2006 12:55 pm
I'm no expert, but i thought you can also pull out dents by spot welding a small bit of steel (rivet i guess), and using a slide tool tap it out.
Then just grind the rivet off and smooth, fill and paint...
Santo
"The Lone Ranger"
HI-HO Silver......AWAAAAAY!
PostPosted: Wed Apr 05, 2006 1:13 pm
tru, We did something similar to remove a large dent from my old car. I don't really like the idea of making more un-neccessary marks in the car.
Howw big is the dent?
PostPosted: Wed Apr 05, 2006 1:18 pm
Not very big. Just like someone has rested there elbow on it. If I did take the rooflining out would it just push out, or is there a special way of doing it?
PostPosted: Wed Apr 05, 2006 1:24 pm
if it really small can't you just spray putty it and paint over???
Santo
"The Lone Ranger"
PostPosted: Wed Apr 05, 2006 1:26 pm
Oh ok. Not sure about the roof-lining & how it comes out. No doubt there's some "special" technique on removing it. Earlier model mini's had a different type of roof-lining compared to the later models....or so I think
PostPosted: Wed Apr 05, 2006 4:05 pm
I meant would the dent just push out, one the roof lining is taken out?
PostPosted: Thu Apr 06, 2006 8:47 am
I guess it would
PostPosted: Thu Apr 06, 2006 8:51 am
The clubbie we just sprayed had lots of dents in the roof...lots.
Most we just didnt bother getting out, would have been a roof of bog otherwise.
Two major dents we just filled in with bog completely, so it was higher than the rest of the roof, sanded it back & then feathered in the edges of the bog with the roof.
Sanded back the entire roof to bare metal again to remove surface rust (apart from newly bogged areas), sprayed red oxide over it all, sanded it all back, then put the primer and paint on.
No more Minis!......For now.
Users browsing this forum: drmini in aust and 95 guests
