It is currently Wed Aug 13, 2025 6:15 am
 Post subject: daily driver blues
PostPosted: Fri Apr 07, 2006 8:00 am
Hey i thought I'd have whinge so bare with me. My car as most of you lot know just had the engine redone but now my clutch is slipping I'm replace the cylinder on tuesday but god it sucks being limited to power I now have. Ohhh well its murphy's law really when its your daily driver I guess doesn't mena I have to be happy about it though. It slips only when i accerate a lil harder and its a ning nong to get into 2nd from 3rd too I'd lead to believe that he clutch cyulinder is my problem so Im doing that dyno and replace htre master brake on tuesday so all should be good by then.
thanks I needed that whinge...
PostPosted: Fri Apr 07, 2006 10:22 am
double clutch it till then hey
PostPosted: Fri Apr 07, 2006 12:28 pm
master or slave cylinders will have no effect on clutch slip. Check the stop on the end of the relase bearing shuttle is adjusted corectly - also make sure there's a gap bewteen the clutch arm and the adjuster bolt with the clutch disengaged...
Cheers, Ian
PostPosted: Fri Apr 07, 2006 2:24 pm
thanks I'll take a look at that before she goes into Mini Classic on tuesday....with anby luck it'll be fixed as a matter of course. luckily its the only thing that wrong it could be worse.... ohh and sometimes double clutching dont work either its real good lol..........
thanks for your advice
Zack
Users browsing this forum: Bing [Bot] and 298 guests
