It is currently Tue Jul 22, 2025 5:33 pm
 Post subject: auto box
PostPosted: Sun Apr 09, 2006 8:40 am
hello,
this is for a friend again,
he is wondering if he buys a mini that is manuel can he convert it into a auto and how much would this aprrox. cost?
thanks in advance.
~sumanovic
 Post subject: Re: auto box
PostPosted: Sun Apr 09, 2006 9:37 am
sumanovic wrote:
hello,
thanks in advance.
~sumanovic
Yes he can....and if he is handy it shouldn't cost too much....may have to change or modify the front subframe......
go and see Steve at Brickworx, ergh Brickworks, ergh...however he spells it :!:
PostPosted: Sun Apr 09, 2006 9:44 am
he has limited skills with cars, and would have to get someone to do it for him.
thanks 4 the help tho...
~sumanovic
 Post subject: OK
PostPosted: Sun Apr 09, 2006 9:51 am
Well.....Steve can certainly help him auto-up a Mini.....wonder if he runs a payment plan :!: :idea: :roll:
your friend could always go this way.....
http://www.ausmini.com/forums/viewtopic.php?t=17981
PostPosted: Sun Apr 09, 2006 9:54 am
Subframes are different for autos.
They are a bit wider, the front channel is curved outwards, and the engine mounts are different too.
Also, the cylinder block has a different oil supply system, it comes up from the autobox's filter- and there are a couple of oilways that the auto block doesn't have.
Driveshafts (on the Oz MiniMatics) use Hardy Spicer couplings (same as Cooper S).
Best bet is get a complete motor/autobox/subframe/driveshafts.
The old ones here were all 998s, I'd go for an ex-Japan low mileage 1275 auto front cut from Brickworx. :wink:
PostPosted: Sun Apr 09, 2006 10:09 am
sorri, i have a lack of knowlegde with auto boxes in minis,
are ther any major problems or issues with them???
or is it better to have a manuel..?
~sumanovic
PostPosted: Sun Apr 09, 2006 10:16 am
your friend is probably best off buying a late model import auto... you'd pretty much have to take the whole front end out of an auto car to put it in a car that was a manual, as Kev says
PostPosted: Sun Apr 09, 2006 10:17 am
I've had lots of manuals, and 3 autos (2 were in Morris 1300s, same box).
The autos are OK if the oil and filter are changed regularly, but although 4 speed, they are not very smooth.
Also autobox parts are not easy to get here, nor are people that know how to rebuild them.
The autos are slower than a manual as there is a bit more power loss thru the box.
Your call.. :wink:
PostPosted: Sun Apr 09, 2006 10:22 am
I forgot to add - if he bought a front cut from a late model car, the auto subframe would NOT suit any australian built shell - it'll only suit a rover shell as the subframe mounts are different, there is possibly a conversion kit, but I've never heard of one
PostPosted: Sun Apr 09, 2006 1:03 pm
Wrong.
Only thing needs changing is two holes on each side of each "arm" at the back of the subframe, into the floor.
This is not solid mounted like early models, there is a rubber mount between the subframe and the floor.
Top bolts will not fit through the centre hole of an 850 bulkhead, but a quicky with the die grinder will see ease of fitment of said bolt.
That is all.
PostPosted: Mon Apr 10, 2006 9:16 am
Your call.. :wink:
True, I have a 1968 Mini matic (4speed auto) putting the car into gear is sometimes a lil rough. Like drmini said, their ok if the oil and filter are changed regularly.
PostPosted: Mon Apr 10, 2006 9:26 am
High heel ninja
Here is a late model rover automatic mini set up in a 1971 Oz clubman, only mods to fit the subframe was drilling a few holes for the subframe mounts.
Doogie
PostPosted: Mon Apr 10, 2006 9:50 am
I have just (yesterday!) completed building an Auto Moke. The engine/box is a 1990 A+ 1275 inserted into a 1968 Mini Auto front subframe. Everything just bolted in with the correct Auto mounts.
Having driven a couple of early Autos, the 1990 one seems a lot smoother. Also it changes DOWN as you slow down, like a modern car. I don't remember the early Autos doing that. It also has Park, which early Auto's do not.
I too would suggest your friend buys a late model car off someone like Brickworx. It will probably work out cheaper that way than buying a nice early Mini and converting it to Auto, if he/she has to pay someone to do the work.
Brett Nicholson
Greendale (near Ballan) VIC.
1971 Morris Mini Moke
1966 Austin Mini
1965 Morris Mini Traveller
1973 LR Series 3 88
2007 LR Freelander 2
PostPosted: Mon Apr 10, 2006 10:29 am
OMG Brett, COMPLETED?! :lol: :shock:
Will it be there this weekend?
PostPosted: Mon Apr 10, 2006 12:07 pm
Yes, it will be at the Muster this weekend. :D
Still a few details to sort out, gotta adjust the kick-down, tidy up the dash and console, buff the paint, clean and fit the top, but MOPOKE will be there! :)
Brett Nicholson
1966 Austin Mini
1973 LR Series 3 88
