On Saturday I bought another mini. It came with a pile of spares, some new and never used. I'll be sorting it all out soon to decide what to keep for my project and what to sell. Heaps of the bits will end up on the for sale page.
Here's my first-pass list:
5 Contessa 10 x 5 mags with Falken tyres 50%
4 x Wolfrace alloy wheels 10 x 5 no nuts or centre caps
7 x standard mini steel rims 10 x 4.5 no nuts, with tyres
4 x clubman steel wheels, poor condition
2 x Yokohama A008R tyres, 10", 1 left, 1 right, 80% tread
1 x jelly-bean alloy wheel, 10 x 5
Cooper S motor (9FXEY) and gear box 22G1168
1 pair Cooper S drive shafts
1 pair Cooper S steering knuckles
1098 cc engine (1006/) with 12G202 head incl double valve springs
rod change gear box
1 pair flat glass head lights with blue globes, new
1 pair front side lights, new
magnolia speedo 200 km/h, new
magnolia tacho 10,000 rpm, new
magnolia water temp gauge, new
magnolia oil pressure gauge, new
chrome tacho pod, new
Morris 90 mph speedo
Cooper style 3 instrument housing
1 pair hub ball joints, new
1 pair tie rod ends, new
steering rack 2.2 turns, new
1 pair rose jointed adjustable lower arms, new
1 pair rose jointed adjustable track rods, new
spring compressor tool, new
Set of 4 Red coil springs, new
Set of 4 hi-lows
1 pair rear hubs with long wheel studs to suit spacer drums
disc brake pad set, new
rear drum brake shoe set, new
1 pair mini fins brake drums, new
2 x set of brake and clutch master cylinders, poor
1 pair rear brake backing plates and shoes
Dowtt 4-blade variable angle fan, new
over-size water pump pulley
MG metro alloy rocker cover
1 pair rocker cover chrome T-bolts for quick release, new
Distributor, 45DM4 electronic with ignitor pack
Distributor, 45D
Distributor, 43D,
remote change gearbox quick shift lever and bits
set of LCB extractors
45DCOE weber carb with 5" alloy manifold, needs seal kit
3 core radiator
4 core radiator
2 x Paddy Hopkirk alloy accelerator pedal, new
2 x steering column lowering brackets, chrome , new
2 x 1 pair black leather bonnet straps, mini-sport, new
1 pair brown leather bonnet straps, mini-spares, new
1 pair chrome grille buttons, new
cooper grille, new
"S" badge, Speedwell ??, new
alloy gear knob
right hand fuel tank
4 x left hand fuel tank (only one without rust holes)
2 x standard alternators
Moke steel centre steering wheel
850 hinging rear number plate bracket
Clubman rear bumper bar
Clubman / Rover 3 gauge cluster housing (no gauges)
Clubman driver's door with lock, bent
Morris mini shell. Possibly 850
Front and rear rubber subframes complete
Morris interior, poor
Book, David Visard, Tuning BL's A-Series Engine 2nd Edition
Book, Kenneth Ball, Autopress, Mini Cooper 1961-72, 2nd Ed 1972
Photos to come tonight. [edit see below]
M.
