It is currently Sun Aug 17, 2025 8:23 am
Post new topic Reply to topic  [ 35 posts ]  Go to page Previous  1, 2, 3
PostPosted: Thu Apr 13, 2006 8:28 am
Closer to 2"
PostPosted: Fri Apr 14, 2006 1:57 am
Really? Wow..... people need to be careful when buying second hand trailing arms then..... it may end up being 2 inches longer than required :shock:
PostPosted: Fri Apr 14, 2006 10:52 am
It is hard to get the wrong ones. The Moke damper mount is the same distance from the pivot end as a Mini so the damper mount stud/bolt sticks out before the stub axle. Unlike a mini where they are in-line.
Here are some I prepared earlier..
PostPosted: Fri Apr 14, 2006 11:07 am
i did have a plan...........
but it seems the only way to get this to work is to move in inner rim further in to give a bigger dish, and more clearance of the trailing arm.
Image Image
PostPosted: Mon Apr 17, 2006 10:47 pm
I don't think you'd get them confused.
But you would be scratching your head if you fitted them and the wheel fouled at the back of the guard :lol:
