It is currently Wed Aug 20, 2025 9:58 am
 Post subject: Brake and Clutch
PostPosted: Fri Apr 14, 2006 1:17 pm
Can anyone tell me I got a set of new brake and clutch master cylinders (plastic type) and they didn?t seem to fit in there appropriate spot until I swapped them. Are they the same thing or are they different? I hope this makes sense??can anyone help?
PostPosted: Fri Apr 14, 2006 1:18 pm
Bore size differences?????
PostPosted: Fri Apr 14, 2006 1:26 pm
Mmmm, not sure about this as it originally had tins and I wanted to go to the plastic ones mmmm??? :(
PostPosted: Fri Apr 14, 2006 1:38 pm
Doing some surfing on the net it looks like they have to go in back to front.
Do you mean like one should face forward and one face back?
Like this?
PostPosted: Fri Apr 14, 2006 1:46 pm
um no they are the shorter ones, but I think that?s how they will have to be mounted.
PostPosted: Fri Apr 14, 2006 1:55 pm
Yeah, that's what I meant I suppose, these are the origianl type for mine, and I think the new ones you may have are slightly different in design. Same job though..
PostPosted: Fri Apr 14, 2006 2:12 pm
Photobucket is down atm so once it is back up i will post a pic.
PostPosted: Fri Apr 14, 2006 2:18 pm
[quote]support bacteria[/quote]
Work at IMVS do you ????
its also a culture that grows.
PostPosted: Fri Apr 14, 2006 2:53 pm
like this i guess
PostPosted: Fri Apr 14, 2006 4:57 pm
Yeah, but the clutch and brake master cylinders have different bore sizes i think?
PostPosted: Fri Apr 14, 2006 5:06 pm
yes i think you are right and after lots of look on the net i seem to find these mounted this way so i am guess it is right
PostPosted: Fri Apr 14, 2006 5:51 pm
Mounted with both facing the firewall will drive you crazy trying to get the brake fluid into the resevoirs without spilling any on the flash looking paintwork.
PostPosted: Fri Apr 14, 2006 11:19 pm
on a closer look i found min/max lines on the back so i figured this is the way that it fits an early model mini, i don't know just guessing :?
PostPosted: Sat Apr 15, 2006 8:34 am
Yes that is the way original tin tank ones were too, they were handed like these new ones so you cannot mix them up.
Good idea, considering the number of Minis out there that had 0.7" Clubby brake MCs incorrectly used on clutches instead of proper 0.75" ones.... and people wondering why they had clutch throwout probs.:x
:idea: If you want to save your paintwork, just carry a small plastic funnel... :wink:
