It is currently Wed Aug 20, 2025 9:22 pm
 Post subject: Battery Sticker?
PostPosted: Sat Apr 15, 2006 9:59 pm
Is it an upside-down Blue triangle - Solid
or is it an upside-down blue triangle with the arrow going down the middle pointing down?
Image Image
PostPosted: Sat Apr 15, 2006 10:05 pm
It is a blue triangle. It does not matter which way up you have it.
If the battery is fitted with a cut out switch the blue triangle has a red spark across it.
I've seen an upside down and right way up solid blue triangle , plus one with a lightning type jagged line in the middle of it . I thought the reg's normally just said a blue triangle to indicate the position of the battery ....
PostPosted: Sat Apr 15, 2006 10:14 pm
The blue triangle is to show the location of the battery.
The blue triangle with the red spark is to show the location of the cut out switch.
PostPosted: Sat Apr 15, 2006 10:53 pm
thanks fellas,
Image Image
Users browsing this forum: No registered users and 374 guests
