It is currently Wed Jul 16, 2025 9:38 pm
 Post subject: No Spark
PostPosted: Mon Apr 17, 2006 7:26 pm
Hi,
The car is a standard 1100 clubman 71. When trying to start, I have spark at the points but no spark at the plugs. Obviously the car won't fire. Any tips.
Thanks
PostPosted: Mon Apr 17, 2006 7:30 pm
Check the condition of the rotor button , distributer cap and the plug leads . Check also that someone hasn't put a little bit of plastic on the end of the coil lead or similar . Also check the little carbon tip is still in the centre of the distributer cap .
PostPosted: Mon Apr 17, 2006 7:42 pm
Had the same problem this week, has spark at the points but not at the plugs.... It turned out my new coil crap itself, do you have a spare coil you could try?
PostPosted: Mon Apr 17, 2006 8:11 pm
yer follow what sport 850 said it shouldnt be your coil if u have spark at the points
PostPosted: Thu Apr 20, 2006 5:59 pm
Hi,
My spare coil fixed the spark problem to the plugs. Still won't start. Will have check timing.
thanks
